Jeetu Sharma Posted March 18, 2021 Share Posted March 18, 2021 @Mehmet Volga it was transmissions overheating. You’re right maybe I was switching too often... gotta understand this overtime. Till then will follow Marshal advice of driving in D for the newbie drives 3 Link to comment Share on other sites More sharing options...
Lakshmi Narasimhan Posted March 18, 2021 Share Posted March 18, 2021 5 minutes ago, jeetu sharma said: @Mehmet Volga it was transmissions overheating. You’re right maybe I was switching too often... gotta understand this overtime. Till then will follow Marshal advice of driving in D for the newbie drives Driving on D you will face this problem frequently, try driving in manual mode on the by lanes in traffic that helps a lot to understand when to switch. 3 1 Link to comment Share on other sites More sharing options...
Mehmet Volga Posted March 18, 2021 Share Posted March 18, 2021 Often getting stuck and trying for self recoveries also may cause transmission overheat. Continuous switching between the gears D-R-N to recover from a stuck may heat transmission, especially if the weather is hot. 4 1 1 Link to comment Share on other sites More sharing options...
Warren Flay Posted March 26, 2021 Share Posted March 26, 2021 Update: 2016 Pajero SWB, front bashplate fitted. Second drive with Carnity March 26. 24 degrees at start and up to 40 degrees celsius by end of drive, no stucks or refusals, used Tiptronic shift exclusively (2nd and 3rd gears only) No overheating at all. 3 Link to comment Share on other sites More sharing options...
Lakshmi Narasimhan Posted April 28, 2021 Share Posted April 28, 2021 Installed both transmission cooler and radiator fan with switch control, looks functional will give feedback by Saturday. 1 1 Link to comment Share on other sites More sharing options...
Jeetu Sharma Posted May 10, 2021 Share Posted May 10, 2021 On 4/28/2021 at 11:04 PM, Lakshmi Narasimhan said: Installed both transmission cooler and radiator fan with switch control, looks functional will give feedback by Saturday. Hi, How's the new setup working? any feedback? 1 Link to comment Share on other sites More sharing options...
Lakshmi Narasimhan Posted May 10, 2021 Share Posted May 10, 2021 Just now, jeetu sharma said: Hi, How's the new setup working? any feedback? Its good no issues till now. With switch control its much better. 1 Link to comment Share on other sites More sharing options...
Jeetu Sharma Posted May 10, 2021 Share Posted May 10, 2021 1 minute ago, Lakshmi Narasimhan said: Its good no issues till now. With switch control its much better. Do any of these setups VOID your warranty? I was informed by one garage that additional fan will not VOID it but just seeking more opinions/ knowledge 2 Link to comment Share on other sites More sharing options...
Lakshmi Narasimhan Posted May 10, 2021 Share Posted May 10, 2021 23 minutes ago, jeetu sharma said: Do any of these setups VOID your warranty? I was informed by one garage that additional fan will not VOID it but just seeking more opinions/ knowledge No it will not, even habtoor service advisor told to fix one. 1 Link to comment Share on other sites More sharing options...
Jeetu Sharma Posted May 10, 2021 Share Posted May 10, 2021 13 minutes ago, Lakshmi Narasimhan said: No it will not, even habtoor service advisor told to fix one. Sorry for all the questions...but since you have fixed the fan can you recommend a garage and if cost estimate. I see AED250 from a garage in Sharjah Link to comment Share on other sites More sharing options...
