Peter Hager Posted October 8, 2021 Share Posted October 8, 2021 Hi! I would need some advice on which type of rope to buy. Length, strength, type and more. Thanks in advance. Peter 1 Link to comment Share on other sites More sharing options...
Frederic Posted October 8, 2021 Share Posted October 8, 2021 Have a look at below article: For off-road recovery, look for a kinetic recovery rope, made from nylon. The AOR ones are quite popular and available in ACE and Speedex for around 400dhs. 3 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Peter Hager Posted October 8, 2021 Author Share Posted October 8, 2021 thx what about an equilizer? 1 Link to comment Share on other sites More sharing options...
Anoop Nair Posted October 8, 2021 Share Posted October 8, 2021 AOR ropes are available in adventure HQ also around 420/- Aed , but the AOR soft shackles are quite pricy around 185/- a piece 1 Link to comment Share on other sites More sharing options...
Frederic Posted October 8, 2021 Share Posted October 8, 2021 1 hour ago, Anoop Nair said: AOR ropes are available in adventure HQ also around 420/- Aed , but the AOR soft shackles are quite pricy around 185/- a piece Check Amazon for the “Artan” brand Shackles. Lot cheaper than the AOR ones. 2 hours ago, Peter Hager said: thx what about an equilizer? A snatch block you mean ? That’s only being used in winch recovery in very rare cases. I have one and never used it. 2 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Gregory Posted October 9, 2021 Share Posted October 9, 2021 19 hours ago, Peter Hager said: Hi! I would need some advice on which type of rope to buy. Length, strength, type and more. Thanks in advance. Peter Hi @Peter Hager the kinetic rope that I have, I sourced from @Rahimdad last year. Not sure if this is still an option though. It comes with two soft shackles in it's own convenient bag. If I recall correctly, it was under AED400, and pulling strength/potential is around 8 tonnes. Hope this helps. 1 Link to comment Share on other sites More sharing options...
Peter Hager Posted October 12, 2021 Author Share Posted October 12, 2021 On 10/9/2021 at 1:25 PM, Gregory said: Hi @Peter Hager the kinetic rope that I have, I sourced from @Rahimdad last year. Not sure if this is still an option though. It comes with two soft shackles in it's own convenient bag. If I recall correctly, it was under AED400, and pulling strength/potential is around 8 tonnes. Hope this helps. Link to comment Share on other sites More sharing options...
