Morning Fewbie Plus Desert Drive - Lisaili - Technical Challenge - Dubai - 06 Jul 2024
DP1011
Drive Plan :
The drive will be testing the skills of handling small technical dunes that the desert of Lisaili offers and will require LOT of patience, right control of RPM , hence its termed - Technical Challenge .  IF you are looking for a fast pace roller coaster drive, then this one is not for you :D . We will be offered with to deal with soft sand, with super tight patches and keeping appropriate distance will be another key requirement of this drive.
Considering summer and rapidly increasing temperature levels, we will start the drive at Sharp 5.20 latest - hence please aim to be at meeting point at or before the time mentioned i.e  5:15am!
Level:  Fewbie plus and above
When: 06 July Saturday
Meeting time:  5.15 AM - Sharp
Meeting Point: https://maps.app.goo.gl/taDoGGgPsdFbsuBR7
Approximate finish time: 8.45 am
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm, and willingness to learn.
RECOMENDED OFF-ROAD GEAR:
  • Tire deflator & Tire pressure gauge
  • Compressor (MANDATORY)
  • Walkie-talkie radio (MANDATORY)
  • Off-road flag (MANDATORY)
  • Shovel, Tow Rope & 2 Shackles
  • First-aid kit
  • Fire extinguisher
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM.
  • RSVP will close a day prior to preparing a convoy list.
  • Latecomers will be returned - Without any exceptions.
  • Members without RSVP will be returned - Without any exceptions.
  • Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
  • Repeated no-show members after RSVP will have their account suspended for a month.
PLEASE RSVP ON THE CALENDAR
  • Carnity changed the title to Morning Fewbie Plus Desert Drive - Lisaili - Technical Challenge - Dubai - 06 Jul 2024
Happy Friday to all the Aspirants of Technical Challenge :) ( RSVP CLOSED)
@Anoop Nair @Deepak Eswar @Rafey Hashmi @Shiju Raju @Mahesh_ @Brett Eicher @Andrew John Melvill @Amr A @christian
Convoy order will be shared later during the day - hence Please accordingly update your RSVP if need be.
Please note the meeting point : https://maps.app.goo.gl/kxATMQLQTUnu7JNy7
Most importantly  The MEETING TIME : Deflated by or before 5.15 AM-  Today's temperature was better in Mid 35s even at 9.30, so am hoping we will weather God in our favour tomorrow.  WE WILL MOVE 5.20 LATEST and we aim to exit in about 3 hours time approx.
We will start our drive with the famous Lisaili entry point with some brisk pace just before hitting the Technical patches, also encounter some vegetation as we continue to make our move towards chimney with some of the most challenging technical dunes on our way.
Ensure all your gears are in place securely tied down with ratchet straps in the rear compartment of the vehicle. Bungy type tie downs are not suitable for tying down off-road gear.
Looking forward to seeing you tomorrow morning !
DP
DP
Hi all - Below convoy order !  See you deflated 5.15am !  - DEPENDING ON HOW THE MOVEMENT IS, WE WILL HAVE SOME SWAPS IN CONVOY POSITIONS :)
Hi all
few pictures
Andrew John Melvill
Thanks @DP1011 for another drive that lived up to its title! Good technical terrain linked togeter by streches of "jungle". A good number to refusals and stucks as should be expected on a tech drive, some really soft sand tested the cars and drivers over and above the tight dunes. But lots of good humor and laughs along the way!
@DP1011The drive was excellent, and I enjoyed the morning. and also could learn/brush up on my technical skills. Though we faced some refusals, we managed to exit more or less on time. I look forward to joining your next technical drive, like the three-hour drive. Thank you.
