Pajero V8 makes noise
Khan2024
Hi @Khan2024
from what you have discribed this noise could be caused by one of the following :
1. as @Frederic mentioned Rear Cv Axel (but the noise needs to be consistent )
2. Rear Propeller shaft ( if the noise is happening while in 2wd and in 4WD )
3. One of your rear wheels Hubs Bearings are a bit loose and needs to be tighten up . You will hear the noise when shifting from D to R and from R to D but the noise will disappear after moving .
