Jeep Maintenance Procedures - Common Additional Services
Jeep Automatic Transmission Fluid Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms.
Jeep Automatic Transmission Fluid/Filter Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. The filter should be replaced at this time a well. This service should be performed every 2 years or 70,000 kms.
Jeep Brake Fluid Replacement/Flush
Brake fluid accumulates moisture and contamination from component wear over time and unless replaced every 50,000 kms or 2 years, can cause brake system damage.
Jeep Cabin Air Filter Replacement
Over time the Cabin Filter(s) will accumulate dirt, pollen and debris which can leak in to the passenger compartment if left unchecked. They should be replaced every year or 25,000 kms.
Jeep Coolant Replacement/Flush
Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,0000 kms.
Jeep Differential Fluid Replacement - Front
Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
Jeep Differential Fluid Replacement - Rear
Jeep Drive Belt(s) Replacement
Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 70,000 kms.
Jeep Fuel Filter Change
The Fuel Filter becomes restricted as it accumulates debris from filtering the fuel which, can lead to performance problems and early fuel pump failure. It should be replaced at the mileage interval recommended by the vehicle manufacturer.
Jeep Manual Transmission Fluid Change
The Manual Transmission fluid breaks down and becomes contaminated with moisture over time and can lead to transmission damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
Jeep Spark Plug Replacement
Spark Plug terminals wear down over time and can lead to engine misfires and increased exhaust emissions. Replace according to the vehicle manufacturers recommended replacement interval.
Jeep Transfer Case Fluid Replacement
Transfer Case fluid breaks down and becomes contaminated with moisture over time and can lead to transfer case damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
  • Carnity unpinned this topic
