where is the fuel pump located
tim
-fuel pump located under rear seat (right side looking forward )
-working inside the car lift the rear seat
-Pull up rubber grommet which cable goes through
-remove circular steel cover plate
-disconnect mutliplug on top of pump
-unscrew bezel using hammer & punch
-Pull up pump from tank
-replace with new pump ensuring that rubber seal doesnt get kinked
-replace bezel
-connect mutliplug and test before replacing steel cover
-Ensure no leaks, even take car for a ride to ensure no leaks
-if tests ok then replace steel cover and grommet, & seat.
should take about 30mins taking you time.
