I am looking 4 instructions on changing power steering belt.
On the pump there is a bracket with an adjuster on it, loosen the bolt designed to tighten the bracket from slipping after the adjustment is set and the pump pivot on the opposite side.
Then loosened the long adjuster bolt to allow the pump to swing.
A little bit of light oil on the threads will aid turning them.
best of luck
