Massaget Posted December 18, 2011 Share Posted December 18, 2011 Hi,guys! I have one trouble with my QX4 electric:in the way,after 82-85 km/h speed 4wd warning lamp will light up and 4WD shift lamp will switch(( Maybe somebody know what is this?! Link to comment Share on other sites More sharing options...
sharmaa Posted December 21, 2011 Share Posted December 21, 2011 Looks like your 4wheel is engaged and that's why it throws the light of 4W after 82kmph as you should never drive 4W cars with 4W on normal tarmac road more than 80kmph. Switch of 4W and you will be fine. Link to comment Share on other sites More sharing options...
Massaget Posted December 21, 2011 Author Share Posted December 21, 2011 Looks like your 4wheel is engaged and that's why it throws the light of 4W after 82kmph as you should never drive 4W cars with 4W on normal tarmac road more than 80kmph. Switch of 4W and you will be fine. Hmmm,thanks again.I read manual before of the use 4x4 car:) But my 4wd knob on normal road everytime is in 2WD position(rear wheel lamp on)-I think the problem in some electric part... Link to comment Share on other sites More sharing options...
humsafar Posted December 22, 2011 Share Posted December 22, 2011 Try to engage and Disengage 4x4 while driving at various speeds with Jerks, it worked for me, may be it wiil work for you as well, another option is to remove the negative terminal of your battery and let it sit there for half an hour, then tight the negative again, it should fix your problem. Link to comment Share on other sites More sharing options...
Massaget Posted February 27, 2012 Author Share Posted February 27, 2012 I think and I hope that the problem is in dirty Dextron in a transfer gear or previous owner puted there some transmission oil-not Dextron III! Link to comment Share on other sites More sharing options...
