quper Posted April 6, 2011 Report Share Posted April 6, 2011 where can we check the transmission fluid on 2005 Land Rover 4 thanks Link to comment Share on other sites More sharing options...
lrmate Posted April 13, 2011 Report Share Posted April 13, 2011 If there is no transmision dipstick, it means transmission oil is made for life. However you if leaking and need to top up, you need to unbolt top up bolt on transmission from down. Link to comment Share on other sites More sharing options...
iroc Posted May 9, 2011 Report Share Posted May 9, 2011 There is no dipstick on the LR4 or for that matter on any new age cars to check your transmission level. No transmission fluid is filled for life. Lifetime generally refers to the life of the vehicle warranty. It is just that you have extended changing intervals. To keep the tranny in good condition, considering the extreme weather, it would be ideal to have it renewed every 100k. Link to comment Share on other sites More sharing options...
