how can i temp. add air to my suspensions in Range Rover
the air suspensions have failed and are sagging which has made it very difficult to move my RR as it has bump stops. i need a solution that will blow up some air in them so that i can atleast drive to the mechanic to change the suspensions to coil.
Jump start the EAS relay by jump wire and compressor will start in half key position (Dont start the car). Let it run for 5 min to fill air in tank and remove the jump wire and start the car and soon it will inflate the balloon with present air in tank. As soon as vehicle lift up hit the inhibit switch on dash so that it doesn't level the ride and again loose all air. With this temp technique you can at least drive RR without jumping like bullock cart.
