cost of changing Universal Joint?
markw
Universal joint also known as cross, is very cheap to fix. Its not at all expensive item, should be less than 100 - 200 dhs. Installation is also fairly simple and cheap, but bigger question is why it has been removed, whats the bigger issue getting hidden behind this??? (IF ANY)
Some big issues cud be: 4x4 is bad, drive shaft is bad, front differential is bad... Go sniff around, before buying.
