qinsley Posted April 29, 2012 Report Share Posted April 29, 2012 Can a water pump failure cause damage to an engine? It seems there's a lot of issues with the water pumps with this model so I wanted to know if it can escalate to a bigger problem like engine failure. Link to comment Share on other sites More sharing options...
praneyd Posted May 5, 2012 Report Share Posted May 5, 2012 Which year model you are referring to??? Water pump is an integral part of engine cooling system. If water pump fails, then car will overheat within SECONDS and fry your engine and car stalls immediately. Check the water pump by pushing the fan blade in twisting pattern other side than its axis. If radiator fan has a little or more play then that means water pump is gone or about to go soon. Link to comment Share on other sites More sharing options...
Nehmaiz Posted May 7, 2012 Report Share Posted May 7, 2012 praney what car are you talking about? radiators on Caymans are in the front of the car and the water pump is mounted on the engine in the middle of the car?!? what has the radiator fan play got to do with the water pump :S... http://www.cartype.com/pics/7924/full/p ... away10.jpg ###PORSCHE NUT EXTREME### Link to comment Share on other sites More sharing options...
