Gaurav Posted August 8, 2017 Share Posted August 8, 2017 Thanks @treks for lovely find. Worth reading Extract from above link: Mitsubishi Diamond SP-II and SP-III— Mitsubishi fluid. Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Sidshk Posted August 8, 2017 Author Share Posted August 8, 2017 1 hour ago, Gaurav said: Thanks @treks for lovely find. Worth reading Extract from above link: Mitsubishi Diamond SP-II and SP-III— Mitsubishi fluid. is it same as image i shared, so i can take it Link to comment Share on other sites More sharing options...
Gaurav Posted August 8, 2017 Share Posted August 8, 2017 Yup it should be good, just check what exact spec mention in your owners manual before buying SP-II or III. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Sidshk Posted August 8, 2017 Author Share Posted August 8, 2017 33 minutes ago, Gaurav said: Yup it should be good, just check what exact spec mention in your owners manual before buying SP-II or III. Does any one have E-Manual of Pajero ?? Link to comment Share on other sites More sharing options...
Gaurav Posted August 8, 2017 Share Posted August 8, 2017 Which year model you have? Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Sidshk Posted August 8, 2017 Author Share Posted August 8, 2017 14 minutes ago, Gaurav said: Which year model you have? 2008 LWB 3.00 Ltr Link to comment Share on other sites More sharing options...
Gaurav Posted August 8, 2017 Share Posted August 8, 2017 Check the first pic look similar to your age Pajero? As I am not sure if its exact 2008 owners manual or not. Hope it helps. Best is go to Habtoor with car registration card and ask for "Genuine MITSUBISHI Power Steering Fluid". http://www.mitsubishi-motors.bg/uploads/files/8_file.pdf Go to refill capacities Page 9-16 2 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Sidshk Posted August 8, 2017 Author Share Posted August 8, 2017 (edited) 56 minutes ago, Gaurav said: Check the first pic look similar to your age Pajero? As I am not sure if its exact 2008 owners manual or not. Hope it helps. Best is go to Habtoor with car registration card and ask for "Genuine MITSUBISHI Power Steering Fluid". http://www.mitsubishi-motors.bg/uploads/files/8_file.pdf Go to refill capacities Page 9-16 Fluid type Use “Genuine MITSUBISHI Power Steering Fluid” or “ATF DEXRON III/DEXRON II”. Edited August 8, 2017 by Sidshk Link to comment Share on other sites More sharing options...
desertdude Posted August 8, 2017 Share Posted August 8, 2017 Oil eh, always ruffles the feathers around here! If it was for the transmission I'd say stick with OEM and all this discussion is kinda pointless, since its for the power steering. Which in this Pajero is basically nothing but a hydraulic pump and ram. And the manual itself as posted says its fine to use Dex II or III, so really not that much of an issue. Much ado about nothing! Yes some cars require fancy pants oil even for steering but this is not the case here. Any reasonable brand Dex II or III should be fine, as long as its not made from old samosa and paratha ghee refined in a shed in Ajman. 1 Link to comment Share on other sites More sharing options...
Gaurav Posted August 8, 2017 Share Posted August 8, 2017 4 hours ago, Sidshk said: Fluid type Use “Genuine MITSUBISHI Power Steering Fluid” or “ATF DEXRON III/DEXRON II”. You read what you wanted and I read what I wanted, that's all I have been explaining since beginning. Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
