Jeh Posted September 17, 2019 Share Posted September 17, 2019 My front tyres are getting worn out from inner side. What could be the issue? 2 Link to comment Share on other sites More sharing options...
syedyaseer Posted September 17, 2019 Share Posted September 17, 2019 Check wheel alignment. May be one of the reason. 1 1 Link to comment Share on other sites More sharing options...
shadow79 Posted September 17, 2019 Share Posted September 17, 2019 Get it aligned they can spot if you have some other issue or only alignment will fix it... 1 1 Link to comment Share on other sites More sharing options...
Gaurav Posted September 17, 2019 Share Posted September 17, 2019 Go for Lazer wheel alignment where they can accurately spot and adjust the toe-in and camber, looks like either of them they are out. Then rotate the tires and use the rear ones in front. Find a shop near you who has Hunter Wheel alignment as they are very accurate machine and they are very common in Dubai in good alignment shops. 1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Srikumar Posted September 17, 2019 Share Posted September 17, 2019 Any idea how much do they charge for Laser Alignment? 2 Link to comment Share on other sites More sharing options...
shadow79 Posted September 17, 2019 Share Posted September 17, 2019 Nothing beats the manual rod and rope alignment but sometimes it takes quite a few trys to get it right... 1 Link to comment Share on other sites More sharing options...
Gaurav Posted September 17, 2019 Share Posted September 17, 2019 54 minutes ago, Srikumar said: Any idea how much do they charge for Laser Alignment? 150-200 dhs, depending on your bargaining skill as it might starts from 400 and go down slowly. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Gaurav Posted September 17, 2019 Share Posted September 17, 2019 55 minutes ago, shadow79 said: Nothing beats the manual rod and rope alignment but sometimes it takes quite a few trys to get it right... Seriously, then why you drive modern engineering cars and why not bullock cart with rope and ox in front. This hunter system is one of the most advance system to catch 1/10 of a decimal difference. I know this as I suffered in my Patrol due to BF goodrich and wasted tons of money and time on rope specialist and in end got this lazer alignment and went home with a big smile. In those days it was quite special as only one shop in Deira had this machine who was installing tires for cooper tire from renaissance trading, but these days this hunter machines has become industry standard and I have seen them in lot of good places. 1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
desertdude Posted September 17, 2019 Share Posted September 17, 2019 Unfortunately the old P38 is a body on ladder frame chassis with solid axels front and rear with no camber adjustments front or rear. But its worth to have to alignment and toe in and out checked. From the workshop manual here are the factory specs If everything checks out then you have a bent front axel and diff tube! Typical problem with patrols and jeeps who jump them alot in the desert 1 hour ago, shadow79 said: Nothing beats the manual rod and rope alignment but sometimes it takes quite a few trys to get it right... 1 hour ago, Gaurav said: Seriously, then why you drive modern engineering cars and why not bullock cart with rope and ox in front. LOL I'm calling this condition Ajmanitis !!! 1 1 Link to comment Share on other sites More sharing options...
Jeh Posted September 17, 2019 Author Share Posted September 17, 2019 5 hours ago, Gaurav said: Go for Lazer wheel alignment where they can accurately spot and adjust the toe-in and camber, looks like either of them they are out. Then rotate the tires and use the rear ones in front. Find a shop near you who has Hunter Wheel alignment as they are very accurate machine and they are very common in Dubai in good alignment shops. I dont thing option is viable for this model. As per my mechanic for this model its a must to do manual alignment. I reckon the same solution was suggested for your Chevy right? 1 Link to comment Share on other sites More sharing options...
