Newbie/Fewbie Desert Drive - Al Qudra - 17 Jan 2020
Srikumar
@Incognitoes Welcome to Carnity Off-road Club. Could you please share the following details:
1. Do you have any previous offroading experience?
2. Ensure that your front and rear recovery points are in good condition
@Obaid.Sultan.1987 Low gear is different than the manual mode. Share the pics of driver side right hand side all knobs and buttons on center console.
For tow hook, check the owners manual and I guess you need to remove small plastic piece to reveal the back hook, if it has hitch hole then you need a hitch receiver too.
Interesting line up with cars.
If i didn’t sleep well, I might come as a passenger and do some recording from a passenger seat.
Any seat free from one of the Marshalers?
The sweep would be better.
Obaid.Sultan.1987
@Gaurav... thanks for guidance... I kept on reading & searching for the same again.
Well now I know more about the LO Gear mode & how the switch looks like.
The switch on the far lower right side with two options // HI (with Highway mark) & LO(with mountains mark) on it ... that’s the Low Gear Option.. I did some research last time as well but I think it wasn’t good enough..
hope to be right this time.. haven’t gone to car but almost looks like the attached pic (pic is from older model though).
however, will test its function tomorrow to make it sure it works fine.
cheers!
You’re welcome to join me buddy. I’ll be sweeping most probably.
  • Well Done (+2) 2
@Xaf you are most welcome to join us a passenger. We have plenty of cars that you can use for different angles.
@Obaid.Sultan.1987 you are right on Low gear option, just make sure it engages well and move the car little bit, few meters in parking without any blinking light. Just dont dont drive on low gear on tarmac.
Welcome @Incognitoes to carnity offroad club.
1 hour ago, Incognitoes said:
Thanks Gaurav. I'm a newbie with a Wrangler JK : would like to join the drive this Friday.
Look forward to meeting everyone.
On 1/13/2020 at 2:44 PM, Tbone said:
Hi, I’m just a beginner and would like to explore more about off-roading. Was a bit hesitant to venture out alone. Saw about this event online and would love to join.
I drive a H3, hope its good enough.
I'll be fun to see how the H3 does on sand . I am sure the seasoned drives must have seen for me it will be the first time .
