Sidshk Posted January 26, 2020 Share Posted January 26, 2020 This is or someone else who is not yet member. He drives Paj 2010 3.5 Now below are some of issue he faces There is Vibration from back of the car between 80-100 Kms and there is some sort of propeller sound Post 100 to 120 There is no vibration, after 125 and above there is vibration in the steering wheel What can be possible cause ? 1 Link to comment Share on other sites More sharing options...
Srikumar Posted January 26, 2020 Share Posted January 26, 2020 11 minutes ago, Sidshk said: There is Vibration from back of the car between 80-100 Kms and there is some sort of propeller sound Does the sound increase with the speed or does it disappear? If it increases it could be a case of failing bearings or noise from tyre. Swap the tyres with the front and see if the sound from the rear reduces. 1 1 Link to comment Share on other sites More sharing options...
Sidshk Posted January 26, 2020 Author Share Posted January 26, 2020 Just now, Srikumar said: Does the sound increase with the speed or does it disappear? If it increases it could be a case of failing bearings or noise from tyre. Swap the tyres with the front and see if the sound from the rear reduces. both vibration and Noise dies after 100 Kms 1 Link to comment Share on other sites More sharing options...
Srikumar Posted January 26, 2020 Share Posted January 26, 2020 3 minutes ago, Sidshk said: both vibration and Noise dies after 100 Kms Then check the condition of the tyres. Might have developed some uneven surface 1 1 Link to comment Share on other sites More sharing options...
Sidshk Posted January 26, 2020 Author Share Posted January 26, 2020 5 minutes ago, Srikumar said: Then check the condition of the tyres. Might have developed some uneven surface Tyre are new 2019 - Only Six months 1 Link to comment Share on other sites More sharing options...
treks Posted January 27, 2020 Share Posted January 27, 2020 19 hours ago, Sidshk said: Tyre are new 2019 - Only Six months Some tyres are bad right from the start. Have them checked out at a proper tyre shop. 1 1 Link to comment Share on other sites More sharing options...
Sidshk Posted January 27, 2020 Author Share Posted January 27, 2020 8 hours ago, treks said: Some tyres are bad right from the start. Have them checked out at a proper tyre shop. tires are fine , He has checked it from Bridgestone store 1 Link to comment Share on other sites More sharing options...
desertdude Posted January 27, 2020 Share Posted January 27, 2020 Sounds like a wheel balancing issue Possibly amplified by some worn bushing or bearing 2 1 1 Link to comment Share on other sites More sharing options...
Sidshk Posted January 28, 2020 Author Share Posted January 28, 2020 13 hours ago, desertdude said: Sounds like a wheel balancing issue Possibly amplified by some worn bushing or bearing Exactly, This is wat we found out last night there is some issue with one or multiple Bushes but the problem is we cannot identify which one. 2 Link to comment Share on other sites More sharing options...
desertdude Posted January 28, 2020 Share Posted January 28, 2020 5 hours ago, Sidshk said: Exactly, This is wat we found out last night there is some issue with one or multiple Bushes but the problem is we cannot identify which one. Lift the car up. then first hold the tyre at the 3 and 6 o'clock positions and jiggle it then the 12 and 6 and do the same 5o check for play. Then Take a tie rod and jam in between all the bushes and give it push and pull and see which bush has excessive play or is visibly cracked or squished 1 1 Link to comment Share on other sites More sharing options...
