Jefy Posted June 1, 2020 Report Share Posted June 1, 2020 1 hour ago, Jorge Stepniak Felippe said: I have a Land Rover LR4 2015 model Hi Jorge, I went quickly in the specs of your car, they come with different trims. As I understand, they come standard with a central difflock, that is only engaging if you go out of the normal highway mode. See below link. Then there is a trim that comes with a rear difflock. does yours come with a rear difflock? 1 1 Link to comment Share on other sites More sharing options...
Najeeb Mohammed Posted June 1, 2020 Report Share Posted June 1, 2020 1 hour ago, Xaf said: Do you have difflocks? I think you have a rear difflock. The switch is at your rear mirror. Have you ever engaged it? I have never used it, but yes it does have a rear difflock but not sure how to engage etc. i shall try next drive. 2 Link to comment Share on other sites More sharing options...
Jefy Posted June 1, 2020 Report Share Posted June 1, 2020 (edited) 1 hour ago, Najeeb Mohammed said: I have never used it, but yes it does have a rear difflock but not sure how to engage etc. i shall try next drive. This is your homework for your next drive; - Read page 187 till 190 please - 196 till 199 is also interesting. https://www.toyota.com/t3Portal/document/om-s/OM35A88U/pdf/OM35A88U.pdf#page187 Edited June 1, 2020 by Xaf 2 1 Link to comment Share on other sites More sharing options...
Chaitanya D Posted June 1, 2020 Report Share Posted June 1, 2020 I would like to add my name to the waitlist for this fewbie drive. @Emmanuel please let me know if any vacancy arises. This current global crisis is causing no vacancies everywhere 🤣 2 3 1 Link to comment Share on other sites More sharing options...
Emmanuel Posted June 1, 2020 Author Report Share Posted June 1, 2020 10 hours ago, Najeeb Mohammed said: I have never used it, but yes it does have a rear difflock but not sure how to engage etc. i shall try next drive. If you want, I can definitely manage to get you crested so that you can try your difflock 😝 1 5 1 Link to comment Share on other sites More sharing options...
Jorge Stepniak Felippe Posted June 1, 2020 Report Share Posted June 1, 2020 Hi Xaf, My model is different from the video you shared so I am not sure the type of difflock I have. When I am in the desert I turn off the DSC (dynamic stability control) to gain more traction. I got crested last time and needed a fellow member help to pull me out 3 1 Link to comment Share on other sites More sharing options...
Najeeb Mohammed Posted June 1, 2020 Report Share Posted June 1, 2020 9 hours ago, Xaf said: This is your homework for your next drive; - Read page 187 till 190 please - 196 till 199 is also interesting. https://www.toyota.com/t3Portal/document/om-s/OM35A88U/pdf/OM35A88U.pdf#page187 Thank u, let me do some homework before i hit the next drive 4 1 Link to comment Share on other sites More sharing options...
Jefy Posted June 2, 2020 Report Share Posted June 2, 2020 6 hours ago, Jorge Stepniak Felippe said: Hi Xaf, My model is different from the video you shared so I am not sure the type of difflock I have. When I am in the desert I turn off the DSC (dynamic stability control) to gain more traction. I got crested last time and needed a fellow member help to pull me out Which engine do you have? 2 1 Link to comment Share on other sites More sharing options...
Gaurav Posted June 2, 2020 Report Share Posted June 2, 2020 On 5/31/2020 at 6:42 PM, Jolly Abraham said: I want to join😀 @Jolly Abraham added you to this drive. 20 hours ago, Chaitanya D said: I would like to add my name to the waitlist for this fewbie drive. @Emmanuel please let me know if any vacancy arises. This current global crisis is causing no vacancies everywhere 🤣 I and Emmanuel (Trip lead) highly recommend you to join a newbie drive first with your new Xterra and get used to this new ride in the desert. Secondly, solar park is quite technical and tricky at few places, you might loose confidence. Please put your join in request in any newbie, and trip lead will add you. 1 1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Chaitanya D Posted June 2, 2020 Report Share Posted June 2, 2020 32 minutes ago, Gaurav said: @Jolly Abraham added you to this drive. I and Emmanuel (Trip lead) highly recommend you to join a newbie drive first with your new Xterra and get used to this new ride in the desert. Secondly, solar park is quite technical and tricky at few places, you might loose confidence. Please put your join in request in any newbie, and trip lead will add you. I had signed for sweihan which is now changed to Qudra morning. I am already signed in when I check the RSVP, please clarify @Srikumar. Wallah habibi... no vacancies everywhere 🤣😉! 3 Link to comment Share on other sites More sharing options...
