LED Light bar questions
Christian Andras
Lakshmi Narasimhan
1 minute ago, Niki Patel said:
Either way, if you can avoid drilling into the body work to do the roof install (install on a roof rack instead) you can then relatively easily play around with the configuration.
Yes I am installing roof rack, I forgot to mention that.
Since my parents and relatives are lined up for Dubai visit, I have gone for bigger tent.
I am getting lights from China,  shipping free of cost through a customer and Installation is little cheaper and one time, it didn't hurt me a lot. I am considering to remove   lights when not required to avoid noise, drag etc after going through all the post
Thanks for your suggestion and reminding me about longer cables.
This gives you license and freedom to experiment :)
1 hour ago, Niki Patel said:
maybe an option is to run the light bars side by side on the front (2 light vs 5 light install and wiring work?)
I agree with this as you need as max light (watt and lumen) as possible in front for driving.
Side shooters are good for small range and you can add two more spot on front bumper left and right (optional) along with hood left and right (plenty).
I would remove the light from front grill, to not to block air flow.
Last but not least upgrade to higher amp battery and alternator.
Lakshmi Narasimhan
Thanks for the suggestion.
Edited by Lakshmi Narasimhan
Correction
Lakshmi Narasimhan
Please discard the above pics, here is my front view where to fit the lights on front bumper sides
On 4/19/2021 at 10:24 AM, varunmehndiratta said:
Hi @Chaitanya D that's why I suggested you to switch to Jeep when you switch...🙂
100 easy fixes for anything like this in Jeep.
Lakshmi Narasimhan
I totally forgot this aspect! Thats the reason need to take suggestion from experts. If I add auxiliary battery will that be fine?
Lawrence_Chehimi
Do you have warranty on your car? If yes I wouldn't touch any of the electricals on the car...
Lakshmi Narasimhan
@Pacific thanks for sharing the pics, jeep always has many way to modify and urs looks good. As @Gaurav , @Niki Patelsuggested i don’t want to block the air. I will ask guys to fit on the sides some how.
Yes, but adding auxiliary battery will void warranty?
Ashok chaturvedi
6 hours ago, varunmehndiratta said:
This would be good for a Iftar party in desert...awesome ..looking forward for being on same night drive (don't think it would be night anymore
With all these lights maybe a second battery should be installed... :-)
