Rizwanm2 Posted May 16, 2021 Share Posted May 16, 2021 with the GCCVIN decoder you can check the vehicle specs and details. here is the link. https://www.vindecoderz.com/EN/check-lookup/5N1AN0N61BC501592 its a factory offroad version. it should have all around yellow bilstein shocks. i bought my xterra about 9 months back. that is also after continues search for about 4 months. I came across lot of lemon cars during my search specially offroad version. my advice is don't buy in a hurry do the research and test drive as many as possible. when you test drive couple of cars you will notice flaws in each once. try to test drive a low mileage high priced pristine onces as well even though its out of your budget. then decide the right one for you and get it thoroughly checked it from a trusted mechanic. Good luck.. 😊 3 1 2 Link to comment Share on other sites More sharing options...
Gaurav Posted May 16, 2021 Share Posted May 16, 2021 9 minutes ago, Rizwanm2 said: my advice is don't buy in a hurry do the research and test drive as many as possible. when you test drive couple of cars you will notice flaws in each once. try to test drive a low mileage high priced pristine onces as well even though its out of your budget. then decide the right one for you and get it thoroughly checked it from a trusted mechanic. Good luck.. 😊 Million dollar advise. Time spent in searching is better than time and money spending in fixing. 3 1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
