kinetic rope
Peter Hager
Have a look at below article:
For off-road recovery, look for a kinetic recovery rope, made from nylon. The AOR ones are quite popular and available in ACE and Speedex for around 400dhs.
1 hour ago, Anoop Nair said:
AOR ropes are available in adventure HQ also around 420/- Aed , but the AOR soft shackles are quite pricy around 185/- a piece
Check Amazon for the “Artan” brand Shackles. Lot cheaper than the AOR ones.
2 hours ago, Peter Hager said:
thx
what about an equilizer?
A snatch block you mean ? That’s only being used in winch recovery in very rare cases. I have one and never used it.
19 hours ago, Peter Hager said:
Hi!
I would need some advice on which type of rope to buy. Length, strength, type and more. Thanks in advance.
Peter
Hi @Peter Hager the kinetic rope that I have, I sourced from @Rahimdad last year. Not sure if this is still an option though.  It comes with two soft shackles in it's own convenient bag. If I recall correctly, it was under AED400, and pulling strength/potential is around 8 tonnes. Hope this helps.
