Recommended Mitsubishi Pajero Winch installation !!
Hey Desert buddies ,
I need an advice for a recommend winch ( brand / Model ) and a recommend installation for my Pajero 2011 LWB. As i  have been asking around , but some people over complicate it ( rocket science ) and others over simplify it ( to a limit you feel scared ) and safety is the number one concern here i don't want to end up installing a 12,000 LBS winch with some bolts or brackets that are rated at 50KG 😂🙈, neither install some over bulky brackets that will make the car hard to drive
thank you in advance for sharing your experience with me
Warn winches are great, so are Smittybilt winches, if you're going for a winch though, know what your usage will be, if its in sand you need a synthetic rope, if you're in rocky and mountainous regions you need a metal one. I know a few garages that will sell you one and install. For a recommendation, for your car i would say VR EVO 10-S WINCH - 103253 is decent, it uses a synthetic rope. Warn winches come with bolts and everything you need apart from a location to mount your winch. Let me know if you need more help.
Edited by Harshal
@Harshal Thanks for your input , i will appreciate it if you could share with me some garage who will know how to install it properly.
I don’t have a winch on my truck as I will change my bumper for a higher clearance one.
Hi Simon, sharing the business details aren't allowed to keep unbiased views than spamming meaningful replies with shop names.
I'm sure you can google WARN winch offered by the various off-road garages in UAE, get 3 quotes based on google reviews, and you will find the winner.
For the WINCH, I am using TJM for 3+ years (barely used) and they are also equally good and reliable as WARN, as they both are AUS brands and trusted by serious offroaders.
Also, I agree as Harshal mentioned, to go with synthetic rope if you are not into mountains and wadi. It's less messy than the metal cable that starts fraying after a couple of pulls. Same fraying experience in my current TJM and previous WARN winch I had.
  • 3 weeks later...
@Gaurav thanks for the information,  after shopping around i thunk warn is the best option , even less weight than the others. My only problem is currently with the fabricatiin as apparently pajero needs to have a fabricated winch mounting brakets .
Thanks
