CANCELLED Afternoon Fewbie Plus Desert Drive -Murqab - Dubai - 13 Feb 2024
M.Seidam
DRIVE DESCRIPTION
Welcome to Carnity off road club Fewbie drive, meeting and ending at Lisalli meeting point, please ensure your off-road gear is as per your rank and you bring lots of enthusiasm with you as this drive will also include a couple of stops for additional theory and visualization of driving Techniques in the sand.
DRIVE DETAILS
Level:  Fewbie Plus and above
When:  13 February 2024, Tuesday
Meeting time:   16:00 - Sharp (Without any exceptions)
Meeting Point: TBA
Approximate finish time:  19:00
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit, Tow Rope, 2 Shackles and fire extinguisher.
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM.
  • Please withdraw your RSVP, if you find you are unable to join, so your spot can be taken by others in the waitlist.
  • If the RSVP is full, you can add your name to the waitlist, if an RSVP attendee removes themselves, you will be moved from the waitlist to the RSVP list as an attendee.
  • A convoy list will be sent out the day prior to the drive.
PLEASE RSVP ON BELOW CALENDAR
  • M.Seidam changed the title to CANCELLED Afternoon Fewbie Plus Desert Drive -Murqab - Dubai - 13 Feb 2024
