Afternoon Fewbie Desert Drive - Lisalli Chimney Loop - Dubai - 30 Nov 2024
DRIVE DESCRIPTION
Welcome to Carnity off road club Fewbie drive, meeting at Lisalli meeting point, please ensure your off-road gear is as per your rank and you bring lots of patience, enthusiasm and that all important willingness to learn with you.
This drive will be Featuring: @Benje_Junior plying his newly gained leader skills giving us freshly baked creative lines as he lead us through the Lisalli dunes.
DRIVE DETAILS
Level:  Fewbie and above
When:  30 Nov 2024, Saturday
Meeting time:   14:00 (2PM) - Sharp (Without any exceptions)
Meeting Point: https://goo.gl/maps/KGF6L8VwXMza3tJz7
Approximate finish time:  18:00 (6PM)
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
Mandatory off-road gears: Fewbie and above, Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit, fire extinguisher, Intermediate and above, Tow Rope and 2 soft Shackles.
Note: Please ensure that all of your off-road gear is securely tied down with ratchet straps in the rear compartment of the vehicle. Bungy type tie downs are not suitable for tying down off-road gear.
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM.
  • Please withdraw your RSVP, if you find you are unable to join, so your spot can be taken by others in the waitlist.
  • If the RSVP is full, you can add your name to the waitlist, if an RSVP attendee removes themselves, you will be moved from the waitlist to the RSVP list as an attendee.
  • A convoy list will be sent out the day prior to the drive.
PLEASE RSVP ON BELOW CALENDAR
  • DP1011 changed the title to Afternoon Fewbie Desert Drive - Lisalli Chimney Loop - Dubai - 30 Nov 2024
@shary I see you are waitlisted for this drive, however, I am afraid i will have to remove you as this drive is a Fewbie level and your current rank is only Newbie. I am looking forward to welcoming you onto a Fewbie drive as soon as you have achieved the correct rank.
Good evening, Sand Seekers  @Andrei S @Ahmed Farouk @Shahid Mehmood @Mahmut @Mohit Gurnani I see that you guys are all on the waitlist for this weekends drive. Unfortunately we can’t take everyone here however @DP1011 has kindly offered to take you on a FB+ morning drive Saturday 30th of November from 0730 to 1100
If there is any interest please reply to this post or like it. And I’ll let DP know.
This goes for other FB+ drivers @Giacomo @frederic demolder  @Haneef Thayyil @Shiju Raju if this option sounds interesting let me know, otherwise we can make it another FB drive if that’s the preferred preference
much appreciated, Ben
Edited by Benje_Junior
Additional drivers
10 hours ago, Andrei S said:
Hi @Benje_Juniorand @DP1011 will it be the same route?
Hi @Andrei S - Not really. I aim to explore More towards Murquab and then time permitting technicals of Lisalli.
Starting from Lisalli.
Dear desert wanderers,
@Andrei S @Ahmed Farouk @Shahid Mehmood @Mahmut @Mohit Gurnani @Giacomo @frederic demolder  @Haneef Thayyil @Shiju Raju as @Benje_Junior has said above, @DP1011 has kindly offered to put on a FB+ morning drive Saturday 30th of November from 0730 to 1100,
So far the interest is as below
 @Shiju Raju, @Shahid Mehmood, @Giacomo
Tentative @Andrei S (please confirm if you would like to join the morning adventures)
If anyone else would like to join the morning Fb+ drive with @DP1011 please let us know soonest so we can start to plan tomorrows adventures.
Appreciated in advance.
