M.Seidam Posted June 28, 2025 Share Posted June 28, 2025 Hello and welcome to Carnity offroad club . few points worth mentioning here regarding desert driving in the night , more to be emphasized and reminded during the brief at the meeting point . 1. No need for offroad lights except for car number 1 . If you have them that’s ok to use them unless the front car asks kindly to let it off. All what you need is just to follow strictly the front car . The high beam stock lights/fog lights are adequate in convoy trips 2. Always see where you step ( hand torch or headlight ) during inflation , deflation and during the breaks. 3. Try to avoid the bushes when out from car . 4. it’s highly recommended to have your legs and feet covered as creepers like exposed feet and legs 😅 5. always carry your radio where ever you go. 6. the speed and distance between cars falls into half of that during daylight drive ( will talk more in the brief ) 7. Desert driving rules holds valid and more emphasized here as we are bound with limited visibility. last but not least night drives are different world to explore and experience. It’s nice , cool and it’s another level of enjoyment . Once you master it I assure you that you will be able “ to see without seeing and to you the darkness will become as clear as the daylight “ We request every member who joins this drive to go through the information below and strictly follow these guidelines, etiquette, and responsibilities. MUST READ AND COMPLY Environmental Policy Offroad Flag Guideline Two Way Radio Guideline Off road Driving Etiquette's Emergency details for all off-roaders Off Road Driving - Roles & Responsibilities First time with Carnity Off-road Club: Please share your vehicle details - Make, Model, Color, and Year. Please share your prior off-road experience. Confirm your vehicle has front and rear tow hooks/eyelets. Confirm you have a programmable radio with Carnity frequency. Confirm you have a compressor and safety flag. MUST WATCH: NEWBIE VIDEO BRIEFING Drive Details Level: Newbie and above (all levels) Meeting time: 8 pm Meeting Point: https://maps.app.goo.gl/cPKMdXfifthzfigR8 Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance. What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm and willingness to learn. Approximate finish time: 11:50 pm P.S. Only join if you have a compressor to inflate your tires after the drive. LIMITED SPOTS AVAILABLE: This drive is limited to 12 cars only. RSVP will close on Friday - 9 AM. If the RSVP is full, you can add your name to the waitlist, once anyone drops, you will be moved to the RSVP list. RSVP will close a day prior to preparing a convoy list. Latecomers will be returned back - Without any exceptions. Members without RSVP will be returned back - Without any exceptions. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month. Please RSVP on below calendar Link to comment Share on other sites More sharing options...
Warbs Posted July 3, 2025 Share Posted July 3, 2025 Apologies if this has been detailed, will the drive finish at the meeting point? If so, is it safe to leave a vehicle there for the duration of the drive? Link to comment Share on other sites More sharing options...
M.Seidam Posted July 3, 2025 Author Share Posted July 3, 2025 7 hours ago, Warbs said: Apologies if this has been detailed, will the drive finish at the meeting point? If so, is it safe to leave a vehicle there for the duration of the drive? Drive will end either in the same meeting point or in another nearby 10 min by car back to the meeting point . I would say yes the area of meeting point is flat and many cars comes and goes . The alternative is to park it in last exit parking which is also 10 min away from meeting point . 2 minutes ago, M.Seidam said: Drive will end either in the same meeting point or in another nearby 10 min by car back to the meeting point . I would say yes the area of meeting point is flat and many cars comes and goes . The alternative is to park it in last exit parking which is also 10 min away from meeting point . Most probable exit point https://maps.app.goo.gl/CKsxHCkPcTzj9KAu5?g_st=ipc last exit parking https://maps.app.goo.gl/AathXxMsB6oGEo3h8?g_st=ipc 1 Link to comment Share on other sites More sharing options...
M.Seidam Posted July 3, 2025 Author Share Posted July 3, 2025 Dear friends @Faraz94 @Warbs @INSTINCT @Zahid Sharif @Amal Sunil @Ana @Andrew John Melvill @Soap @JC_E @Dipu Francis @Zulfikhar Naiyar @Mahesh_ Please note RSVP is closed we will use radio channel 2 Please be on time 8 pm or bit earlier at the meeting point specified in the drive topic above . Please find convoy order below 4 Link to comment Share on other sites More sharing options...
INSTINCT Posted July 4, 2025 Share Posted July 4, 2025 Running late. Vl try reachn asap. Link to comment Share on other sites More sharing options...
M.Seidam Posted July 4, 2025 Author Share Posted July 4, 2025 18 minutes ago, INSTINCT said: Running late. Vl try reachn asap. How much time you need as we are bound with time every one is here almost dear 8pm Link to comment Share on other sites More sharing options...
INSTINCT Posted July 4, 2025 Share Posted July 4, 2025 Just reached i tried. Nxt ride then. Sorry Link to comment Share on other sites More sharing options...
Soap Posted July 4, 2025 Share Posted July 4, 2025 (edited) Thanks Doc for an amazing drive. Driving in the night is a whole new experience! Edited July 5, 2025 by Soap Typo 2 3 Link to comment Share on other sites More sharing options...
M.Seidam Posted July 5, 2025 Author Share Posted July 5, 2025 Thanks @Soap for the nice snaps for memories. 1 Link to comment Share on other sites More sharing options...
M.Seidam Posted July 5, 2025 Author Share Posted July 5, 2025 Highlights of Qudra II Newbie Night Drive : Thank you all for being even a head of time which shows how punctual and passionate you are . Respect 🙏 Seeing full house families , meeting new faces and chit chatting during the breaks with humor and big smiles is all what are these drives are about after all 🙏 all convoy despite some tricky spots did more than great and this reflects how when we stick to the rules of desert complications are the least to happen. In fact in this particular drive apart from couple refusals there were no stucks no ropes out neither shovels were needed. Faraz in the second lead , Andrew in the middle and Mahesh tailing the convoy were truly the back bone of the convoy helping when ever needed. Big thank you guys 🙏 I wish all of you pleasant weekend and see you in another night drive next week Inshallah ( full moon Night 🌕 ) Cheers Seidam 2 2 1 Link to comment Share on other sites More sharing options...
