Morning Fewbie + (Plus) Desert Drive - Switchbacks & Sandstorms: The Nazwa Triangle Challenge - Sharjah - 13 July 2025
GauravSoni
DRIVE PLAN
a high-adrenaline off-road training loop starting at Big Red, sweeping through Tawi Nazwa, climbing Pink Rock, and returning to Big Red. This route is designed to push your skills with fast-paced ridge runs, sharp crossovers, and dynamic switch tracks. Expect continuous movement, minimal breaks, and technical demands that require full focus and quick reactions. As we progress, the terrain and speed will intensify, preparing you for your next stop-  intermediate-level .
You will learn and focus on :
  • Command over throttle on fast transitions
  • Judging slip side behavior at speed
  • Consistent communication and quick gap closure
  • Positional awareness in dynamic crossover flow
  • Reading terrain and anticipating changes under pressure
This isn’t just a drive—it’s a proving ground. Come sharp, stay alert, and get ready to ride the pink sands like never before.
the drive is expected to start at 5:30 am allowing sufficient time before the "sandstorms" kick in!
DRIVE DETAILS
Level:  Fewbie Plus and above
When: 13 JULY 2025
Meeting time:  5:15 AM
Meeting Point:  https://maps.app.goo.gl/76FHkT2zcWAtRjjR9
Approximate finish time: 8:45 AM
What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm, and willingness to learn.
RECOMENDED OFF-ROAD GEAR:
  • Tire deflator & Tire pressure gauge
  • Compressor (MANDATORY)
  • Walkie-talkie radio (MANDATORY)
  • Off-road flag (MANDATORY)
  • Shovel, Tow Rope & 2 Shackles
  • First-aid kit
  • Fire extinguisher
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only.
  • RSVP will close a day prior to preparing a convoy list.
  • Latecomers will be returned - Without any exceptions.
  • Members without RSVP will be returned - Without any exceptions.
  • Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
  • Repeated no-show members after RSVP will have their account suspended for a month.
Please RSVP on the below calendar event
  • WOW (+2) 1
  • Well Done (+2) 2
  • GauravSoni changed the title to Morning Fewbie + (Plus) Desert Drive - Switchbacks & Sandstorms: The Nazwa Triangle Challenge - Sharjah - 13 July 2025
@GauravSoni you have chosen the right en route for the description of the drive , just reminding me of  “catch me if you can “  .. enjoy every one you have the right lead in the right place image.png.9bf9487650a254b0997e90b54dc32725.png
  • Haha (+1) 2
20 minutes ago, ChrisW said:
Soon, @Sam Selim!
@Martin M You will need to join another drive for the weekend at or below your current level of Fewbie - this is a Fewbie Plus (FB+) level drive.
Thanks @ChrisW, I'm off to Oman this weekend but hopefully @GauravSoni will be planning another one the following weekends 😀
Hi @Martin M, thanks for the note! Just to clarify — this drive is specifically for FB+ drivers preparing for Intermediate, so to join, you need to already be an FB+. Since you’re not yet promoted, I’ll have to ask you to take your time . Hope to have you in a future drive once you’re all set — you’re close, keep going! 😊
Hi  @Alphin Aloor just checking in — last I see is your IM drive in Feb 2025. Have you done any drives with other convoys recently, especially in the past month?
If yes, that’s great and you’re good to join. But if not, I’d recommend doing a lower-level drive first before joining this one — just to stay aligned and safe in the sand. Let me know!
Edited by GauravSoni
