Twilight Fewbie Desert Drive - Lisaili "Sunset Chase " - Dubai - 24 Jul 2025
M.Seidam
Dear sunset chasers , twilight lovers and sand cravers hello and welcome to a weekday quick spin exploring the mystical lisaili through the beautiful sunset view where in the second half we will be catching up with the last strings of light to enter the the dark side where we eventually get to the exit most probably at Qudra .
This drive will offer a good opportunity to experience both day and night drives in gradual smooth manner.
please check your car your gear and radios one day prior to the drive .
P.S : offroad lights not mandatory, except for the lead car , in the night portion of the drive and all what you have to do is to make sure that your stock high beam lights as well as the rear lights  are working and to follow exactly the rear red light in-front of you .
DRIVE DETAILS
Level:  Fewbie and above
Meeting time: 18:00 PM (SHARP - Without any exceptions)
Meeting Point: https://maps.app.goo.gl/dtD5gu11gLjqweRWA
Mandatory off-road gears: Fewbie and above, Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit, fire extinguisher, Intermediate and above, Kinetic Tow Rope and 2 soft Shackles.
Note: Please ensure that all of your off-road gear is securely tied down with ratchet straps in the rear compartment of the vehicle. Bungy type tie downs are not suitable for tying down off-road gear.
 Approximate finish time: 21:00 PM
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Wednesday - 12:00 Noon.
PLEASE RSVP ON THE CALENDAR
  • Carnity changed the title to Twilight Fewbie Desert Drive - Lisaili "Sunset Chase " - Dubai - 24 Jul 2025
@khlief@JC_E@Jose Luis Campos@Michael asir@Alex K
Dear friends see you all today by 6 pm please be on time or bit earlier .
convoy order will be done on site
radio channel 2
cheers
  • Totally Agree (+2) 2
@khlief@JC_E@Jose Luis Campos@Michael asir@Alex K@Faraz94
Thank you all for joining the drive yesterday . we could have done more in lisaili but my X decided to choose the limp mode after the first true criss cross . i was searching where is the problem seems its internal burning issue of the engine oil that need to be sorted out ( gasket ( most probably ) , piston ring and communication to the coolant less luckily ..etc ) any way thanks for the extra oil and the patience . after all the secret garden was the savior . i enjoyed chatting with you guys nearby our lovely lake. till we see each other next time take care and have a lovely weekend .
Seidam
Cheers
@JC_E you had to leave us from the start due to some work emergency hope all good
if you don’t mind I am going to remove you from the RSVP as you haven’t practically did the drive 🙏
