HondaDubai Posted August 27, 2011 Report Share Posted August 27, 2011 Honda Maintenance Procedures - Common Additional Services Honda Air Filter Replacement The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms. Honda Brake Fluid Replacement/Flush Brake fluid accumulates moisture and contamination from component wear over time and unless replaced every 50,000 kms or 2 years, can cause brake system damage. Honda Coolant Replacement/Flush Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,0000 kms. Honda Differential Fluid Replacement - Front Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms. Honda Drive Belt(s) Replacement Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 70,000 kms. Honda Fuel Filter Change The Fuel Filter becomes restricted as it accumulates debris from filtering the fuel which, can lead to performance problems and early fuel pump failure. It should be replaced at the mileage interval recommended by the vehicle manufacturer. Honda Manual Transmission Fluid Change The Manual Transmission fluid breaks down and becomes contaminated with moisture over time and can lead to transmission damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms. Honda Sub Item 1: Rotate Tires Inspection of wheels and tires, rotate tires, check and adjust air pressures Honda Sub Item 2: Replace Engine/Cabin Filters Replacement of the Engine Air Filter and the Cabin Air Filter (where applicable) is performed, along with an inspection of the drive belt and drive belt tensioner. Honda Sub Item 3: Replace Transmission Fluid Replacement of the Automatic or Manual Transmission Fluid is performed. Honda Sub Item 4: Perform Valve Adjustment Adjustment of the valves should be performed whether they are noisy or not. The Valve Cover gaskets will be replaces as part of this job. Honda Sub Item 4: Replace Spark Plugs Spark Plug terminals wear down over time and can lead to engine misfires and increased exhaust emissions. Replace according to the vehicle manufacturers recommended replacement interval. Honda Sub Item 5: Replace Coolant Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,0000 kms. Honda Valve Adjustment On engines with adjustable valves, the valve train clearances can become improper which can lead to engine damage. The valve clearance should be checked and adjusted every 50,000 kms. Link to comment Share on other sites More sharing options...
brembo Posted September 24, 2011 Report Share Posted September 24, 2011 coolant replacement and valve adjustment every 50k kms? isnt that way too early? where did you get this info from? Link to comment Share on other sites More sharing options...
zubs Posted September 25, 2011 Report Share Posted September 25, 2011 I agree to coolant flush every 2 years or 50k kms its a very good and must practice. I don't know about Valve adjustment though. Link to comment Share on other sites More sharing options...
shajudheen Posted June 18, 2012 Report Share Posted June 18, 2012 I have purchased 2008 CRV. Near the top of coolant mentioned don't replace the factory coolant till 200,000km, is it true? Link to comment Share on other sites More sharing options...
crazydriver Posted June 1, 2013 Report Share Posted June 1, 2013 in this service procedure the admin has mentioned that Air Filter should be changed once a year but its best to go for twice a year change. Link to comment Share on other sites More sharing options...
