what is a Catalytic Converter?
Catalytic converter is located below the engine. Catalytic converter helps in converting the harmful gases in the car exhaust into harmless compounds. Since gasoline is a major compound in the engine, it results into harmful compounds like nitrogen oxide, hydrocarbons and carbon monoxide. And if at any time if you feel that the converter is faulty, get it changed as soon as possible.
