farhaad Posted October 31, 2013 Report Share Posted October 31, 2013 Hello everyone, I am trying to figure out a way to change the carbon filter on my 407. its been a while and it should be really dirty. Any help would be greatt! Link to comment Share on other sites More sharing options...
adnanz Posted November 4, 2013 Report Share Posted November 4, 2013 With the dust conditions here in the UAE .. its good to change the carbon filter like every 20,000 km !! i keep a eye on it since im asthmatic and the dust just gets to me. There are plenty of to-dos over the internet that you can find and im sure you'll find videos as well .. dont worry if its not a peugeot.. they easy to replace so videos can give you an idea. Link to comment Share on other sites More sharing options...
farhaad Posted November 4, 2013 Author Report Share Posted November 4, 2013 oh okay .. i saw a lot of different processes posted here so i thought if i could get a step by step too .. that'll be great Link to comment Share on other sites More sharing options...
jasim Posted November 4, 2013 Report Share Posted November 4, 2013 Here you go.. The carbon filter is located on the passenger side so slide the seat back as far as it can go ... remove the floor mat just in case .. You might already know about the plastic clip on the panel below the glove compartment. pull the clips out and then the panel. You will find a handle on the panel cover which is located behind the ashtray. After you pull the panel cover away.. you will find the carbon filter. Pull the old filter out and make sure you dont move it too much to get the dirt on yourself. you might have to bend it to take it out completely. Slide in the new one, just make sure the air flow arrow on the filter is pointing up. The panel can be put back till it snaps shut. Replace the top panel with the plastic clips. Done and dusted. Link to comment Share on other sites More sharing options...
farhaad Posted November 5, 2013 Author Report Share Posted November 5, 2013 Thanks Jasim ! appreciate it ... now i dont have to waste time elsewhere ... plus its a chance for me to learn new processes. It sounds easy to do. Link to comment Share on other sites More sharing options...
