Sandeep N Posted April 23, 2025 Share Posted April 23, 2025 how should that have been recovered?? (assuming pulling from the back would have been better as it was slightly lower than the front allowing the car to pivot about the heavier end of the car) or hold/pull with a winch from the top, realign along the slope and allow controllled decent? 1 Link to comment Share on other sites More sharing options...
M.Seidam Posted April 23, 2025 Share Posted April 23, 2025 On 11/16/2024 at 7:52 AM, Looper said: https://www.instagram.com/reel/C_hBVwwSZ5c/?igsh=MTFmcDY5ZXJ2b3ViZA== what went wrong… ?! For this one I would say climbing like this slow in a slip phase will very quickly build up sand wall against the right sided tires ( in this example ) that a very little momentum will topple it . Solution is ATTACK 😄 2 Link to comment Share on other sites More sharing options...
Aser Posted May 5, 2025 Share Posted May 5, 2025 https://www.instagram.com/reel/DHt6ZxbtnW9/?igsh=cWx2MWgzYTUwdW9y Be careful trying to force your way out... 1 1 Link to comment Share on other sites More sharing options...
M.Seidam Posted May 5, 2025 Share Posted May 5, 2025 2 hours ago, Aser said: https://www.instagram.com/reel/DHt6ZxbtnW9/?igsh=cWx2MWgzYTUwdW9y Be careful trying to force your way out... this is another one similar but in faster mode 2 Link to comment Share on other sites More sharing options...
M.Seidam Posted May 5, 2025 Share Posted May 5, 2025 On 4/23/2025 at 8:44 AM, Sandeep N said: how should that have been recovered?? (assuming pulling from the back would have been better as it was slightly lower than the front allowing the car to pivot about the heavier end of the car) or hold/pull with a winch from the top, realign along the slope and allow controllled decent? Very good Sandeep in another words I would say : 1. first of all ( this situation particular ) anchor the car from above by two equal points to acheive control descend . 2. remove the sidewall sand 3. Use long rope ( 2 , 3 or even 4 ropes ) connected by shackles this will make the recovering car to be positioned accurately in proper angle 1 1 Link to comment Share on other sites More sharing options...
M.Seidam Posted May 5, 2025 Share Posted May 5, 2025 I advise everyone to check also recovery situations through the the thread of the greatest of recoveries 1 Link to comment Share on other sites More sharing options...
M.Seidam Posted May 28, 2025 Share Posted May 28, 2025 Summery of some clips .. good for newbie to see it . As a matter of fact useful for every off-roader 👇 5 1 Link to comment Share on other sites More sharing options...
Luke K P Posted August 25, 2025 Share Posted August 25, 2025 https://www.instagram.com/reel/DMgciCIz7Vp/ Think the cause of this is pretty obvious... not quite on ridge.. go full gas to try and get over. 1 Link to comment Share on other sites More sharing options...
_Herman_ Posted August 25, 2025 Share Posted August 25, 2025 Turned so sharp the forward motion was changed to sideways (centrifugal) force very sudden, and as the front wheels had no more traction they couldn’t ‘pull’ the car forward anymore so it quickly lost even more forward speed. Sharp ridge meant quick build-up of resistance digging the side in, not just the back wheels. 2 1 1 Link to comment Share on other sites More sharing options...
Andrew John Melvill Posted August 25, 2025 Share Posted August 25, 2025 @Luke K P, some great learnings from that clip. Needed to stabilize the car on the ridge, transfer the weight over to the slip face. Only then turn down onto the slip face to complete the maneuver. @Herman G great observations from your side on what he did wrong. I have tried to explain how the maneuver should have been carried out. 2 1 Link to comment Share on other sites More sharing options...
