Sidshk Posted October 15, 2018 Share Posted October 15, 2018 I own 2008 Pajero LWB full option and planning to upgrade to Prado as i m getting a very attractive deal, Does it worth the swap and what shall i check before buying the Prado Expert advice please Link to comment Share on other sites More sharing options...
Rahimdad Posted October 15, 2018 Share Posted October 15, 2018 @Sidshk good choice. Toyota Prado is a very capable car with minimum options and one of the reason it never gives you trouble. Toyota reliability. Just the normal things to check like engine, gearbox and chassis. Being an old car it will give you some repair cost, but Toyota is easy and cheap to maintain. Just change all the oils, plugs wire sets, just to be on the safe side. Happy buying. 1 1 Link to comment Share on other sites More sharing options...
Sidshk Posted October 15, 2018 Author Share Posted October 15, 2018 1 minute ago, Rahimdad said: @Sidshk good choice. Toyota Prado is a very capable car with minimum options and one of the reason it never gives you trouble. Toyota reliability. Just the normal things to check like engine, gearbox and chassis. Being an old car it will give you some repair cost, but Toyota is easy and cheap to maintain. Just change all the oils, plugs wire sets, just to be on the safe side. Happy buying. Thanks @Rahimdad just got info its 300000 kms done Link to comment Share on other sites More sharing options...
Rahimdad Posted October 15, 2018 Share Posted October 15, 2018 I have seen a Prado 2008 model with 700k on the clock. All the owner does is get maintenance at regular intervals and doesn't want to sell it. It's a work horse. 1 1 Link to comment Share on other sites More sharing options...
Gaurav Posted October 15, 2018 Share Posted October 15, 2018 Prado indeed is a good buy, and I'm glad that its V6 so it can be equally good for occasional offroad unlike V4. Get the Engine checked properly being 300K, and if it was maintained well in the past then you should be fine. In my company, we have Prado and LC's crossing 500k with very minimal wear and tear. 2 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Barry Posted October 16, 2018 Share Posted October 16, 2018 Do it. I drove a swb turbo diesel Colorado (European model) for a while and it was amazing. Best turning circle of any 4x4 I’ve ever driven. Never had any problems other than a shitty mechanic pouring stopleak into the cooling system which meant changing the radiator, cylinder head and heater matrix. Also had to weld the chassis due to salt infested roads but that will never happen here. 2 Link to comment Share on other sites More sharing options...
shadow79 Posted October 17, 2018 Share Posted October 17, 2018 prado is cash in your pocket you can sell it off anytime you want... 2 Link to comment Share on other sites More sharing options...
