Fuad Posted May 1, 2019 Share Posted May 1, 2019 1 minute ago, Gaurav said: Well A/T light is never good and you should never drive when A/T light is ON. Well, you were lucky that you just lost the transmission that can be rebuilt or replaced, but in some extreme cases it can heat up to an extent to blow off a hose and car catching fire from underneath. Impossible to tackle that fire unless you have fire extinguisher pointing at the base of a burst hose - extremely difficult to trace while the car is catching fire. Yeah exactly. Waiting for New transmission and will be back to meet you guys soon. 👍🏻 Link to comment Share on other sites More sharing options...
Gaurav Posted May 1, 2019 Share Posted May 1, 2019 2 minutes ago, Fuad said: Yeah exactly. Waiting for New transmission and will be back to meet you guys soon. 👍🏻 Oh, you recently busted it, I thought you were telling from your past experience. Sorry to hear that, are you rebuilding or going for scrap one? Which year your Pajero is? Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Fuad Posted May 1, 2019 Share Posted May 1, 2019 1 minute ago, Gaurav said: Oh, you recently busted it, I thought you were telling from your past experience. Sorry to hear that, are you rebuilding or going for swap one? Which year your Pajero is? Got a swap with 2014 gearbox mine is 2012. 1 Link to comment Share on other sites More sharing options...
Derick Posted May 1, 2019 Share Posted May 1, 2019 1 hour ago, Gaurav said: Well A/T light is never good and you should never drive when A/T light is ON. Well, you were lucky that you just lost the transmission that can be rebuilt or replaced, but in some extreme cases it can heat up to an extent to blow off a hose and car catching fire from underneath. Impossible to tackle that fire unless you have fire extinguisher pointing at the base of a burst hose - extremely difficult to trace while the car is catching fire. OMG, where is this AT light comes on and how does it look it? Link to comment Share on other sites More sharing options...
Srikumar Posted May 1, 2019 Share Posted May 1, 2019 It will mention the word AT and would be red in color. You can see the light when you put your key on ignition before cranking 1 Link to comment Share on other sites More sharing options...
Gaurav Posted May 1, 2019 Share Posted May 1, 2019 It comes in the dashboard, instrument cluster while turning half key it comes on for few seconds as self-test everytime you start the car 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Derick Posted May 1, 2019 Share Posted May 1, 2019 Thanks Srikumar and Gaurav Fuad, do you mind sharing how your transmission failed? And what is the advantage of swapping with 2014 model Link to comment Share on other sites More sharing options...
Fuad Posted May 1, 2019 Share Posted May 1, 2019 1 hour ago, Gaurav said: It comes in the dashboard, instrument cluster while turning half key it comes on for few seconds as self-test everytime you start the car In Pajero Gen 4 . This will be the Automatic Transmission Light Link to comment Share on other sites More sharing options...
Barry Posted May 1, 2019 Share Posted May 1, 2019 13 minutes ago, Fuad said: In Pajero Gen 4 . This will be the Automatic Transmission Light Are you sure? I would have said that’s a coolant overheat warning. Not saying you’re wrong, I don’t work on new cars Link to comment Share on other sites More sharing options...
desertdude Posted May 1, 2019 Share Posted May 1, 2019 That IS is coolant overheat warning light, not A/T 1 Link to comment Share on other sites More sharing options...
