Barry Posted July 1, 2019 Share Posted July 1, 2019 I’ve been here for a while now so I kind of know my way around but I’m no expert. I can get myself to a general area but I use google maps to take me to the exact destination. Once I’ve been there, I can always go back without a map and find my way home again. Google maps are good as long as you stay aware of your surroundings and know where you are instead of following it blindly where it tells you to go. Mine still isn’t showing speed. Maybe I need to update it. Totally agree with @Gaurav if it showed the speed limit it would be totes amazeballs. Sometimes you go into a new road and you think the speed limit is something but it is something else. And the first time you find out is when the fine comes through. 2 1 Link to comment Share on other sites More sharing options...
desertdude Posted July 1, 2019 Share Posted July 1, 2019 13 minutes ago, Barry said: I’ve been here for a while now so I kind of know my way around but I’m no expert. I can get myself to a general area but I use google maps to take me to the exact destination. Once I’ve been there, I can always go back without a map and find my way home again. Google maps are good as long as you stay aware of your surroundings and know where you are instead of following it blindly where it tells you to go. Mine still isn’t showing speed. Maybe I need to update it. Totally agree with @Gaurav if it showed the speed limit it would be totes amazeballs. Sometimes you go into a new road and you think the speed limit is something but it is something else. And the first time you find out is when the fine comes through. My ancient khatara Garmin gave speed limits. So does default map app in my slightly less ancient windows 10 phone. 2 Link to comment Share on other sites More sharing options...
Per A Posted July 4, 2019 Share Posted July 4, 2019 THANK GOD FOR GPS! i could get lost in my own pocket so for me its on always but i switch between google maps and Waze as Waze has the road speed and all cameras and will scream at me if im going to fast. But google maps has better navigation or maybe im just used to it.... 2 2 Link to comment Share on other sites More sharing options...
Gaurav Posted July 8, 2019 Author Share Posted July 8, 2019 After this little test, I don't think Google map is inaccurate in showing speed its our dear car manufacturers who are showing 2-4 km less than actual speed for some reason. I have tested with my Range (-4) @ 100 km speed, Trail blazer (-2/3) @ 100 speed, Pajero (accurate) as I run slightly bigger tires and yet driving most of the time close to grace limit allowed and never got any flash. 3 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
shadow79 Posted July 10, 2019 Share Posted July 10, 2019 That speed showing is bit sketchy sometimes you at some speed and it shows 2 dashes.... 1 Link to comment Share on other sites More sharing options...
Gaurav Posted August 22, 2019 Author Share Posted August 22, 2019 Google maps is not showing speed on smaller roads. Noticed this last week in sweihan and now in qudra. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
shadow79 Posted August 23, 2019 Share Posted August 23, 2019 Even if it shows it's not accurate like the purpose built gps which shows speed pretty accurately... 1 Link to comment Share on other sites More sharing options...
Gaurav Posted August 23, 2019 Author Share Posted August 23, 2019 Accuracy has been already discussed above that its more of vehicle issue than the Google maps. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
