Gaurav Posted October 27, 2020 Share Posted October 27, 2020 Congratulations @Desert Dweller, @Foxtrot Oscar, @Pancho for successfully completing the first session of leaders lead with flying colors. Thanks @Jeepie for supporting the first session and sharing your real life experience as a successful new leader. As you all have learned the basics first and demonstrated a perfect way to lead an independent drive in the desert, now it's your chance to work on the routing and planning skills. You will be learning the basics of leading the convoy in the desert in three different steps: Advance sand reading, plan your lead, plan your exits. Use of navigational software for selecting the right course of path. How to systematically scale the lead for all the cars in the convoy. In this second session of leaders lead you will be leading with the help of off-road navigation app or device. You can choose any device or app (motionx, gaia, mytrail etc) and mark these basic points and you will be required to reach any one or few of them: Entry and Exit Solar Park Al Qudra Desert Opp Bab Al Shams Mark long range playable dunes Mark pylon tracks, cycle tracks Mark as many sabka, flat track or easy exits in case of emergency Mark fencing or restricted area Mark technical dunes P.S. I will personally check each of your device to verify and help you further. Approximate Area Perimeter Level: Selected Advance and Above When: 31 Oct 2020, Saturday Meeting time: 6:00 AM, (Sharp, without any exceptions) Meeting Point: https://goo.gl/maps/Y4CCbDkHiWTv54nT8 Solar Park Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance. Approximate finish time: 10:00 AM Please RSVP on the below calendar: 3 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Frederic Posted October 27, 2020 Share Posted October 27, 2020 2 3 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
