Hisham Masaad Posted April 9, 2021 Report Share Posted April 9, 2021 26 minutes ago, Hisham Masaad said: So far @Kailaswalking option is fine, about 19 hours walking🤣🤣, will check other mobile Other two mobiles didn't work @Kailas, selecting close point, worked 🤔 see you then Link to comment Share on other sites More sharing options...
Lawrence_Chehimi Posted April 9, 2021 Report Share Posted April 9, 2021 Same here, Google maps can't find a route. Only option is to walk😂. 1 Link to comment Share on other sites More sharing options...
Varun Mehndiratta Posted April 9, 2021 Report Share Posted April 9, 2021 (edited) Hi @Kailas kindly remove me from drive... As was concerned, i am identified as close contact with someone tested positive for Covid. I have to be in isolation for next few days. Hope the first shot of.vaccine comes in handy for me. Edited April 9, 2021 by varunmehndiratta 1 Link to comment Share on other sites More sharing options...
Hisham Masaad Posted April 9, 2021 Report Share Posted April 9, 2021 1 hour ago, Lawrence_Chehimi said: Same here, Google maps can't find a route. Only option is to walk😂. I thought problem with me only @Lawrence_Chehimi , the problem walking and reaching without car, will not be able to join the drive🤣 Link to comment Share on other sites More sharing options...
Kailas Posted April 9, 2021 Author Report Share Posted April 9, 2021 @Hisham Masaad @Lawrence_Chehimi I have now updated the location . Let me know if its fine now. 1 Link to comment Share on other sites More sharing options...
Hisham Masaad Posted April 9, 2021 Report Share Posted April 9, 2021 1 minute ago, Kailas said: @Hisham Masaad @Lawrence_Chehimi I have now updated the location . Let me know if its fine now. Yes @Kailas was just checking now, and found it is working well. Appreciated thank you 👍 Just now, Hisham Masaad said: Yes @Kailas was just checking now, and found it is working well. Appreciated thank you 👍 First time I checked I was in Sharjah @Kailas, now reached Dubai and checked found it working, thought my location was the problem🤣 Link to comment Share on other sites More sharing options...
Lawrence_Chehimi Posted April 9, 2021 Report Share Posted April 9, 2021 @Kailasit is working fine now👍👍 thanks. See you tomorrow. 1 Link to comment Share on other sites More sharing options...
William Fernandes Posted April 9, 2021 Report Share Posted April 9, 2021 Hi @Kailas regrettably I am going to have to pull out! Still not fully recovered my friend! Enjoy the drive and see you soon. Cheers. Link to comment Share on other sites More sharing options...
Lawrence_Chehimi Posted April 11, 2021 Report Share Posted April 11, 2021 @Kailas, thank you for the amazing drive, the area didn't have much technical terrain and we got the chance to practice a lot criss-crossing, ridge riding and side sloping. @Hisham Masaad, I guess what we were doing wrong yesterday is engaging the Rear Locker and disabling the Traction control. "In order to activate A-TRAC, you must first put your vehicle in neutral, shift into 4LO and press the “A-TRAC” button". You need the traction control to be activated in order for the system to work ( Traction light should be off), and only A-trac should be luminating on the dashboard, in this case the traction control will send power to the wheel that has traction.. Link to comment Share on other sites More sharing options...
Hisham Masaad Posted April 12, 2021 Report Share Posted April 12, 2021 17 hours ago, Lawrence_Chehimi said: @Kailas, thank you for the amazing drive, the area didn't have much technical terrain and we got the chance to practice a lot criss-crossing, ridge riding and side sloping. @Hisham Masaad, I guess what we were doing wrong yesterday is engaging the Rear Locker and disabling the Traction control. "In order to activate A-TRAC, you must first put your vehicle in neutral, shift into 4LO and press the “A-TRAC” button". You need the traction control to be activated in order for the system to work ( Traction light should be off), and only A-trac should be luminating on the dashboard, in this case the traction control will send power to the wheel that has traction.. Thank you @Lawrence_Chehimi for the advice, yes felt there is something wrong, but while you are in the middle of it, thinking and analysing goes in a refusal mode🤣🤣 1 Link to comment Share on other sites More sharing options...
