Dan S Posted December 5, 2023 Share Posted December 5, 2023 (edited) Dears, By any chance, anybody, had the possibility to convert his battery powered tyre compressor to achieve a small air gun capability? I would like to have the chance to blow up the air from my engine or similar locations after each drive and not spending too much in adding a permanent air tank system to the car. Any ideas what we can do in this matter? Thank you in advance! Edited December 5, 2023 by Dan S Link to comment Share on other sites More sharing options...
Gaurav Posted December 5, 2023 Share Posted December 5, 2023 You can buy air blow gun with an adapter that goes on your compressor hose pipe. Something like this: https://www.amazon.com/Beduan-Compressor-Accessory-Connect-Couple/dp/B083F9JGFH?th=1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Dan S Posted December 5, 2023 Author Share Posted December 5, 2023 3 minutes ago, Gaurav said: You can buy air blow gun with an adapter that goes on your compressor hose pipe. Something like this: https://www.amazon.com/Beduan-Compressor-Accessory-Connect-Couple/dp/B083F9JGFH?th=1 Many thanks for the reply Gaurav, I was thinking not having a tank will impact the flow of the air via that air blow gun which will make it almost useless for blowing any dust Link to comment Share on other sites More sharing options...
Gaurav Posted December 5, 2023 Share Posted December 5, 2023 1 minute ago, Dan S said: I was thinking not having a tank will impact the flow of the air via that air blow gun which will make it almost useless for blowing any dust And you are absolutely correct, I have bought one with high hopes and never used again. As the loose or dry sand can be moved while the vehicle is moving, but dry sand stuck with some fluid is hard to get out of the engine bay unless you use car wash blow gun. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Dan S Posted December 5, 2023 Author Share Posted December 5, 2023 11 minutes ago, Gaurav said: And you are absolutely correct, I have bought one with high hopes and never used again. As the loose or dry sand can be moved while the vehicle is moving, but dry sand stuck with some fluid is hard to get out of the engine bay unless you use car wash blow gun. Well understood, many thanks Gaurav for your prompt reply and response. Link to comment Share on other sites More sharing options...
Frederic Posted December 5, 2023 Share Posted December 5, 2023 @Mario Cornejo has this setup with twin compressor ARB with tank. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Dan S Posted December 5, 2023 Author Share Posted December 5, 2023 3 hours ago, Frederic said: @Mario Cornejo has this setup with twin compressor ARB with tank. That will be the best but quite costly at 3500 aed right now as new Link to comment Share on other sites More sharing options...
Cha Posted December 5, 2023 Share Posted December 5, 2023 + cheapest fix, you dont need very high pressure to make this work, and it works very well for the oil sand mixture 2 Link to comment Share on other sites More sharing options...
Dan S Posted December 6, 2023 Author Share Posted December 6, 2023 10 hours ago, Cha said: + cheapest fix, you dont need very high pressure to make this work, and it works very well for the oil sand mixture Thanks Cha, will definitely give it a try Link to comment Share on other sites More sharing options...
Luke K P Posted December 6, 2023 Share Posted December 6, 2023 (edited) 45 minutes ago, Dan S said: Thanks Cha, will definitely give it a try this combo on my bushranger air max 3 compressor doesnt do the job... get some back pressure in the hose and get a small burst of air... then not enough airflow to move sand off my dashboard. Really need tank option (even the arb single compressor with tank should do the job) Edited December 6, 2023 by PETELCZYC PAJERO - luke typos 1 Link to comment Share on other sites More sharing options...
