Morning Fewbie Plus Desert Drive - Lisaili Technical Madness drive - Dubai - 01 Mar 2025
Simon D
DRIVE DESCRIPTION
Welcome to Carnity off road club Fewbie+ drive, meeting at Lisaili . Please ensure your off-road gear is as per your rank and you bring lots of enthusiasm with you as this will be a drive through great variety of terrain with a few challenges.
Please note this drive will consist of some challenging technical terrain, and expected to be mostly a low paced drive . We will try to cross from Lisaili to Qudra through some really challenging technical patches. So get ready to get your hands sweaty :D
DRIVE DETAILS
Level:  Fewbie Plus and above
When:  01 Mar 2025, Saturday
Meeting time:   08:00 - Sharp (Without any exceptions)
Meeting Point: https://goo.gl/maps/KGF6L8VwXMza3tJz7
Approximate finish time:  10:30
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit, Tow Rope, 2 Shackles, and fire extinguisher.
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM.
  • Please withdraw your RSVP, if you find you are unable to join, so your spot can be taken by others in the waitlist.
  • If the RSVP is full, you can add your name to the waitlist, if an RSVP attendee removes themselves, you will be moved from the waitlist to the RSVP list as an attendee.
  • A convoy list will be sent out the day prior to the drive.
PLEASE RSVP ON BELOW CALENDAR
  • Carnity changed the title to Morning Fewbie Plus Desert Drive - Lisaili Technical Madness drive - Dubai - 01 Mar 2025
Dear @khlief,  @Abhishek Chikara, @Michael asir, @J-P L, @Faraz94, @Sherry Jacob, @Deepak Eswar, @Amir Amiri, @Looper
Drive RSVP is now closed !!
Make sure that your car is in a perfect condition and having a "FULL TANK " and have all your gear as per your rank.
Meeting time is 8:00 AM Sharp ( late comers will be sent back )
We will use Carnity Radio Channel 4 " 446.081 Mhz".
The convoy order will be as the following :
Hello @Simon D,
Sorry for informing late, I won’t be joining this Drive.
See you all next time, have fun 😊
Thanks for a varied drive, starting with some nice technical dunes Liseli side moving through some bushy areas on the way towards one of the Qudra lakes and a great surprise of to find clean open dunes to end off with.
@Simon D, Thank you for organising an exciting technical drive! Thought it was planned as a technical drive,  but it turned out to be so much more; which made the drive more interesting; with surprises, such as a stunning scenic route, lush greenery, and a beautiful small lake. Thank you @J-P L for the second lead and @Looper for the support.  Thank you, all fellow drivers.
Looking forward to more thrilling adventures like this!
Abhishek Chikara
Thanks for the great drive @Simon D and to the support team @J-P L and @Looper for getting us out safely.
The part in Qudra was simple amazing - scenic, fast paced, lots of ups and downs -  ending at the lake. Thanks again, had a great time!!
