Morning Fewbie Desert Drive - Sweihan's Hidden Gems - Abu Dhabi - 06 Sep 2025
Frederic
DRIVE DESCRIPTION
Starting from the Tilal Sweihan Race Track, the plan is to explore the entire area and travel South towards the famous Bedford Trucks. Expect a good paced drive with some technical challenges along the way.
Drive Details
Level:  Fewbie and above
Meeting time: 6:30 AM (SHARP - Without any exceptions)
Meeting Point:  https://maps.app.goo.gl/j3gugsF8RJDdQwrw8
Approximate finish time: 10:30 AM
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 1 PM.
  • Repeated no-show members after RSVP will have their account suspended for a month
RSVP HERE BELOW
  • Carnity changed the title to Morning Fewbie Desert Drive - Sweihan's Hidden Gems - Abu Dhabi - 06 Sep 2025
RSVP IS NOW CLOSED
@Soap@Diego@Zahid Sharif@Aser@Krinesh@Danie@Zsolt@ChrisW@Mei Ling@Ahmed Farouk@Mohit Gurnani@Jeandre Bezuidenhout@Faraz94@Zed@Luke K P
Thank you all for signing up!
As you can see we have a big train tomorrow, which no doubt will be great fun, and its great to see this signup even before winter.
As we are in @Luke K P his backyard, he will be leading most of the drive. I will be responsible for the warmup as CEO (Chief Entertainment Officer), where Luke will be our CTO (Chief Tracks Officer) 😆.
With @ChrisW and @Aserin the support, and @Zedin the sweep, our Abu Dhabi team is almost complete.
Please try to arrive 15 mins early. There is an ADNOC nearby the starting point so that is also helpful.
The drive plan will be a mix of technical and some spaced dunes, and the plan is to visit the well-known old Bedford trucks parked in the middle of this area. Once we found them, we will exit at the nearest road, or loop back to the starting point if we still have the time.
We will be using Channel 4: 446.081 Mhz.
See you all tomorrow!
  • Like (+1) 5
  • Well Done (+2) 2
6 minutes ago, ChrisW said:
Hey @Frederic - looking forward to this one!
Just wanted to double double check the meet point - which side of the fence line are we deflating?
Just on the left hand side when you come from the roundabout, But however arrives first decides :)
I've moved the meeting point a bit further down, closer to the cellular tower. That's the spot we usually deflate. Thanks @ChrisW !
Some call it 'closer to the cellular tower', others call it 'closer to the 1am shawarma shack'
@Frederic is this the same Bedford we went in the night drive? (down South towards Khazna)
If so,  @Luke K P  the Three Trees at (24.3604826, 55.1601796)  is a good resting point halfway towards Bedford. Some shades for good coffee & laugh 👍
Yup 👍
Added you @Giacomo as there was a dropout. You can take position 13 in the convoy. See you tomorrow!
