Gaurav Posted October 14, 2025 Share Posted October 14, 2025 Every offroader has had those strange days when you get stuck more than on other days. The same car, the same dunes, the same tire pressure, the same experience, yet somehow you end up getting stuck more frequently. Is it the sand condition changing with temperature, humidity, or wind direction? Could tire temperature, surface tension, or engine torque response be different than usual? Or is it the driver’s rhythm, concentration, or throttle timing slightly off that day? Some even believe that desert energy changes with season or moon cycle, subtly altering traction and density. So what do you think is really at play? Is it science, mechanics, or mindset that determines how easily we get stuck while leading or following? Share your experiences and patterns you’ve noticed on your stuck days. 3 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Frederic Posted October 14, 2025 Share Posted October 14, 2025 Very good topic @Gaurav. In my case it's mostly whenever i feel that i am not relaxed behind the wheel that everything becomes so much more difficult: you start to overthink and hesitate on dune crossings, resulting in refusals and/or stucks. In a relaxed state of mind your mind should flow together with how your car is flowing through the dunes. No worries on your mind and listening to what the car can do for you. The desert itself tells you everything you need but we need to tune in to its frequency.. 6 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
M.Seidam Posted October 14, 2025 Share Posted October 14, 2025 Very good topic to discuss and share. I believe both driver factors and none driver factors come here . my experience: driver factors : I noticed when I drive Solo rarely I get stuck maybe because I choose terrain carefully and focus and concentrate more as I am on my own . However in most of the unlucky situations I am prepared to get away Solo too except my rare cases that mandated leaving my car ( once happened ) or calling for help . On the other hand while I am leading generally I get stuck but less than if I am following . None driver factors can be divided to environmental ( weather change , visibility , sand texture after rain … etc ) and car related ( popout complicating stuck , mechanical …etc ) . i believe that driver factors at least with me takes 80 percent and none driver factors 20 percent 5 Link to comment Share on other sites More sharing options...
ChrisW Posted October 14, 2025 Share Posted October 14, 2025 The biggest variable in getting stuck is probably me! The most common cause of my stucks is basically being too ambitious in the moment. Once you have a feel for your car and some time on the sand, you often have a gut feeling for whether a manoeuvre is going to work or not - and this is usually quick judgement based on a combination of speed/momentum, slope and condition of the ground, and the direction you’re going to steer in. The times I get stuck are usually when I ignore that gut feeling and press on. The other major factor is fatigue and alertness. If I find myself getting complacent while driving (letting myself get distracted with some menu on the car dashboard or basically not giving all of my attention to the driving), that’s a great signal to drink some water, sit up straight in the seat and turn the focus back on. Most of my “incidents” in the desert have been attributable to this. Very, very rarely my car will surprise me and be the cause of getting stuck. The Jeep JL can in some unusual circumstances disengage 4H and fall back to 2H but not tell you. Whilst confusing it’s obvious when this has happened - the car fishtails readily and at low speed will usually just dig in at the back and halt you in your tracks. 6 Link to comment Share on other sites More sharing options...
Gaurav Posted October 14, 2025 Author Share Posted October 14, 2025 After so many years of driving in the sand, I feel like my mind has built its own internal database of every terrain type: when to be adventurous, when to stay cautious, when to explore, and when to just cruise. But every time I step into a new area, or revisit an old one after a long gap, that “database” seems to go offline for a while. The excitement of discovery takes over, and suddenly I’m driving with the curiosity of a six-year-old. That’s usually when I start making the most unexpected mistakes, getting refusals or getting stuck in places where I normally wouldn’t even think twice. It’s almost as if the desert knows when you’re over-eager, and it reminds you to slow down and reconnect before letting you flow again. 5 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Luke K P Posted October 14, 2025 Share Posted October 14, 2025 For me time of day and direction plays the biggest part. As the sun gets higher in sky and sand readability reduces, i'll start getting stuck on obstacles that should have been a no brainer. Drive before 10:00, or after 15:00. Lunch drives are a fools errand! Night driving in a way, is much easier as you always have the shadows from your lights and the sand to show you the terrain exactly as you coming towards it. 3 1 Link to comment Share on other sites More sharing options...
Frederic Posted October 14, 2025 Share Posted October 14, 2025 9 minutes ago, Gaurav said: After so many years of driving in the sand, I feel like my mind has built its own internal database of every terrain type: when to be adventurous, when to stay cautious, when to explore, and when to just cruise. But every time I step into a new area, or revisit an old one after a long gap, that “database” seems to go offline for a while. The excitement of discovery takes over, and suddenly I’m driving with the curiosity of a six-year-old. That’s usually when I start making the most unexpected mistakes, getting refusals or getting stuck in places where I normally wouldn’t even think twice. It’s almost as if the desert knows when you’re over-eager, and it reminds you to slow down and reconnect before letting you flow again. this reconfirms again that our "gut" feeling is extremely crucial in off-roading. I have told to a few people already that i've had a few experiences in the North of UAE dunes where my gut told me not to cross a specific dune. In both cases upon crossing that dune a bit further away i could spot a large tree on the other side. So there is definitely something at play in the desert Of course there are also times that the desert is giving us a nice surprise, but luckily @Srikumarwas there to pull me back in reverse 😁 3 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Gaurav Posted October 14, 2025 Author Share Posted October 14, 2025 Waiting to hear from @Srikumar on his stuck reasons 2 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
M.Seidam Posted October 14, 2025 Share Posted October 14, 2025 Link to comment Share on other sites More sharing options...
Mike M. Posted October 14, 2025 Share Posted October 14, 2025 (edited) Very interesting topic @Gaurav, I strongly believe, and you will hear me mention this everytime I get the chance, that this is a mental hobby before being a physical hobby. Every move, every attempt, every crossing is overcome mentally before even touching the gas pedal. In order to elaborate more pragmatically, I would divide it into outcomes and enablers. The outcome is the mental state of the driver that envisions a successful crossing of the obstacle(s), before the actual attempt. The enablers are the variables and the factors that impact the outcome. I’ll give some examples of the enablers that impact the outcome to elaborate: - A familiar terrain would reduce the heightened mental state and might cause the driver to be complacent due to familiarity - Solo driving on the other hand causes the driver to be in a “Do or Die” mindset because he has no safety net (mind you that solo driving usually means more conservative driving but the logic holds) - Fatigue, whether due to a sleepless night or long driving will impact the outcome and cause the driver not to achieve the expected outcome - Overconfidence, getting creative, or any action mid-maneuver will cause a stuck. The objective for all drivers is to be clear that you need to execute what you intended to do. Any changes to the plan, mid-execution, will cause a stuck and sometimes more dangerous outcomes as well. To summarize: the objective in off-roading is to constantly PLAN IT, ENVISION IT, EXECUTE IT. Every single thing in off-roading goes under those 3 phases, whether it is a single maneuver, a 4-hour drive or a 4-day trip. Once a variable hits any outcome of those 3 phases, you get the negative results of that phase, in the case of your topic, the scenario is a maneuver and it is impacting the EXECUTE IT phase, which results in a stuck. Hope this makes sense folks or else I can get a whiteboard to the desert next time Edited October 14, 2025 by Mike M. 4 Link to comment Share on other sites More sharing options...
