Sonata-2012 Delkor Battery Replacement
Jagdesh: Your car has 68 AMP battery that keeps 600 AMP as a cold cranking Amp. You can get any battery that is close to this spec. Major thing is it should have same or slightly higher AMP not lower. Secondly before buying make sure the size is same as your current one in terms of length and width. You can choose from trane, Solite, AC Delco etc. approx should be within 300 dhs.
More importantly before changing call the dealer and see if this battery is covered under warranty as its less than 2 year old car.
Thanks for comments - Well I have gone for AMARON with Specs 80D26L - 12V 60AH - CCA-500 a week before. No as you mentioned CCA should be either same or higher - SO would it impact on the performance in longer run? I'm really worried now :(
