accident and need help
I wouldnt suggest that as washer fluid is having domestic soap chemical that might hurt engine system and retain in engine jacket even after you flush the radiator.
Better is go under your car and open the radiator drain bolt and let all coolant come out and then rinse radiator with water once before filling coolant.
