Loud Sound in Engine
  • 3 weeks later...
Loud noise from the engine can be because of the exhaust system. May be there is some leak in the exhaust and the gas is blowing out. You need to check the exhaust system. Just follow the sound and try to get to the exhaust system and check if there is any gas/air blowing out with the help of a paper.
  • 4 weeks later...
