Febin Frederic Posted June 28, 2020 Share Posted June 28, 2020 Light bars are kind of over kill in my opinion, unless you are the marshal or lead of the pack. Else a good pair of spot or flood light will serve the purpose. 2 Link to comment Share on other sites More sharing options...
Frederic Posted June 28, 2020 Share Posted June 28, 2020 1 minute ago, Denizzalbayrak said: I can fix it to the bumper but I don’t have enough experience in electrical works The wiring set looks like this. So you have the 2 wires (red and black) to hook up to your LED bar (the ones on the left of the photo). And then you have a red wire (the one with the copper ring) that you need to hook up to the + of your battery. The black wire with the copper ring you can also mount/bolt to your metal frame or chassis, as this is the ground wire. 3 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Denizzalbayrak Posted June 28, 2020 Share Posted June 28, 2020 Thank you @Frederic I will have a look at it. @Febin Frederic headlights of my car are not so good. I need an extra source of light for an appropriate visibility. 2 Link to comment Share on other sites More sharing options...
Rahimdad Posted June 29, 2020 Share Posted June 29, 2020 @Denizzalbayrak please remember you cannot use these off-road lights on road. Link to comment Share on other sites More sharing options...
Denizzalbayrak Posted June 29, 2020 Share Posted June 29, 2020 (edited) 8 hours ago, Rahimdad said: @Denizzalbayrak please remember you cannot use these off-road lights on road. Yes I know @Rahimdad. Thank you for the warning. But do I need to cover them even though they are off? Edited June 29, 2020 by Denizzalbayrak 1 Link to comment Share on other sites More sharing options...
sertac Posted June 29, 2020 Share Posted June 29, 2020 1 hour ago, Denizzalbayrak said: Yes I know @Rahimdad. Thank you for the warning. But do I need to cover them even though they are off? Only for passing 1 1 Link to comment Share on other sites More sharing options...
