Vibration While breaking
Go for the obvious first. vibes under braking 9.5 times out of 10 means warped discs. If they are thick enough you can have them skimmed, or of they are cheap enough get a set of new ones.
Update
Went to workshop  and found my Drums are out (don't knw wats it means ) but has good thickness, so they polished it and fixed it as per mechanic it can work for some more time and no need to worry.
Cost of per drum from Divya spare store - AED 270 + VAT
so as of now just sticking with old , after polish and change of break pads vibrations are almost gone
  • Well Done (+2) 2
5 hours ago, Sidshk said:
Update
It will just come back. There is no way that disc run-out can be polished away.
  • Sad (0) 1
I think its meas it has some imperfection to its shape rather than thickness
Correct.
Drums unlike disks are meants for the rear tires, how would they cause vibration while breaking as the front, disk breaks are used while breaking, drums are only used fro the hand brakes?
@Sidshk you said the vibration is almost gone, have to checked why some vibration is still there?
Its almost not noticeable
