How to recover - side crest stuck safely in desert?
Positioning is very important and then the tug intensity - gradual to constant pull than jerking that may result in flip instantly.
Well done @Emmanuel
Key things for every offroader to notice and learn here:
  • Tried self recovering first to the max.
  • Clear sand from front tires on both sides.
  • Identify a safe spot to recover with least force - Front and left side.
  • Position car with utmost precision to deliver just a minimal tug at right angle.
  • Stuck 4x4 wheels pointing left to support the recovery process by using engine power.
  • Started with a soft tug and then applied a pulling strength and not a jerk to cause a flip.
  • Well Done (+2) 2
