Lawrence_Chehimi Posted June 2, 2021 Share Posted June 2, 2021 7 hours ago, Thomas Varghese said: will be good if you inform the RTA. My Altima triggers the speed cam when over 140 even by 1 km/hr My altima was around 9 digits off. Link to comment Share on other sites More sharing options...
M.Seidam Posted June 2, 2021 Share Posted June 2, 2021 (edited) 8 hours ago, Thomas Varghese said: will be good if you inform the RTA. My Altima triggers the speed cam when over 140 even by 1 km/hr Correction I meant the real speed is less by 10 digit what the speedometer shows . For example my speedometer shows 100k/hr but the actual speed is 90 km per hour so when I am sticking to the board speed limit on my speedometer I am actually driving really by 10 digit less . could be of safety reasons Appolgy for the confusion Edited June 2, 2021 by M.Seidam Link to comment Share on other sites More sharing options...
sertac Posted June 2, 2021 Share Posted June 2, 2021 12 hours ago, Thomas Varghese said: I think its because you changed the tire size the speedo gets wrong reading How you know I changed the tire size. My tire size is same as factory 1 Link to comment Share on other sites More sharing options...
Thomas Varghese Posted June 2, 2021 Share Posted June 2, 2021 40 minutes ago, sertac said: How you know I changed the tire size. My tire size is same as factory I said generally. Not you to be specific. Usually this phenomenon happens when the tire size is changed. Link to comment Share on other sites More sharing options...
Hussein El Zein Posted August 8, 2021 Share Posted August 8, 2021 Hello, I have Xterra 2010 off-road, i did this temperature test yesterday night after driving and car in full heat the engine temp was 105 C and also today morning like 10 am after i reached work also same 105 C. so i guess the engine is over heated in this way, something not normal, also i dont have water leakage, the level always fine. from two months i change head gasket because of water leakage, also water pump and thermometer. from that time the indicator i see it little higher from before. Any ideas what would be the reason ? ill try to check the Fan clutch, but it was working fine before. i didnt have problems until i had leak and the car went into garage. Link to comment Share on other sites More sharing options...
Cha Posted August 8, 2021 Share Posted August 8, 2021 (edited) 1 hour ago, Hussein El Zein said: Hello, I have Xterra 2010 off-road, i did this temperature test yesterday night after driving and car in full heat the engine temp was 105 C and also today morning like 10 am after i reached work also same 105 C. so i guess the engine is over heated in this way, something not normal, also i dont have water leakage, the level always fine. from two months i change head gasket because of water leakage, also water pump and thermometer. from that time the indicator i see it little higher from before. Any ideas what would be the reason ? ill try to check the Fan clutch, but it was working fine before. i didnt have problems until i had leak and the car went into garage. I believe for most of the time temp should be between 85 to 92 onroad, 92 to 105 offroad, and I'm using aftermarket radiator which is smaller in volume compare to the larger GCC original radiator. Neither a night onroad nor a ln offroad drive should bring up the temperature to 105, you need to check it up. May be the radiator has rusted and clotted inside which makes coolant circulation inefficient, due to excessive usage of coolant, and this was the reason why I changed my previous original radiator. Edited August 8, 2021 by Zixuan Huang - Charlie Link to comment Share on other sites More sharing options...
