Morning Fewbie Plus Desert Drive - Nahel Loop - Abu Dhabi - 28 May 2023
Looper
DRIVE DESCRIPTION
Last week when I drove here I mentioned on the drive report that I couldn't have enough of it. So here I am; back another time. Instead of going to Sweihan however, we will do a loop in Nahel Area and exit.
Due to the weather conditions, it will be super hot, super soft with lot of push.  Emphasize check your car, to make sure you don’t have any overheating or any mechanical issues in your car. It's going to be a challenging drive, Hence please be prepared and lets Loop with Looper!
DRIVE DETAILS
Level:  Fewbie Plus and above
When: 28 May 2023 Sunday
Meeting time: 05:00 AM (SHARP - Without any exceptions).
Meeting Point: https://goo.gl/maps/A1Q6WarVVUY2EAPv5
Approximate finish time: 09:00 AM
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit and fire extinguisher.
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on FRIDAY - 12 PM
33 minutes ago, DP1011 said:
@Zed Are you getting petrol from Oman or you discovered a well somewhere in backyard or got all your cars EV ? :D
26th May is already pay day... don't tell the wife that 1000dhs already spent on fuel to Sweihan! 😂
  • Haha (+1) 3
On 5/22/2023 at 7:42 PM, Zed said:
@Looper added WL for 3rd drive... if this is the same track like last time, I want to try the Cherokee V8 this time, see which car can climb higher 😂
It will not go higher i believe.😜
Today's drive was more of "Nahel Loops" than "Nahel Loop" as since we took so many loops around play areas that we had to end the drive at Sweihan side rather than where we started. It was a unique experience doing pretty much the same track compared to last time in the sense that today, it seemed a bit more technical. It could be because of the weather and also becuase the track we took was slightly south compared to last time.
@Ishak, @Zed @M.Seidam thank you very much to all of you for joining the drive.
  • Well Done (+2) 3
Thank you @Looper for the drive today. I was worried that you will cancel this drive 🫡. It was fun, fast pace, climbing side sloping and tugging 😄. I learned to follow exactly your track 😅. So let’s redo it again soon.
Thanks @Ishakas a second lead
Thanks @Zed as CF. Your V8 is really nice.
Thank you dr @M.Seidam as a sweeper, your support and guide.
Nice play area
Edited by Ishak
  • Well Done (+2) 3
There is no wonder , your dream became true 😄and as a lead you looped it my friend in such a way that it was so smooth and enjoyable for sunday morning . Well done and looking for more loops 🔁 following your tracks . Thanks again 🙏
Nice play area
Thank you @Ishak for the nice pictures . You did good today and you gave us a moments to stretch a bit shoveling here or tugging there . Well done
