abdul Posted July 11, 2012 Report Share Posted July 11, 2012 is changing all the brake cables a difficult work or not. The weekend is coming up and i would like to try changing them myself. Appreciate the advise thanks Link to comment Share on other sites More sharing options...
Saleem Posted July 11, 2012 Report Share Posted July 11, 2012 which model you want to work it? Link to comment Share on other sites More sharing options...
Saleem Posted July 11, 2012 Report Share Posted July 11, 2012 some models requires a special tool to return the piston back in the calibers and start with the front tires then make a test drive and change the rear if it is braking fine and you may need an long screw drive to push the piston back after removing the outsider pad and some models require to spin the rear pistons to push it back in place good luck and be safe. please note some models like A8 after 2003 (without hand brake lever) just a park brake switch the rear brake is electro mechanic dont try to push it or spin it you have to use a hand held via OBD2 to bleed them (release them) and the hard way but not recommended for a beginer you can remove the servo motor and start to spin it manualy then tite it and lose 1 & 1/2 turn then install the servo motor back and go for a test drive for auto calibration (self learning) dont forget to install new brake pad waer sensors! Link to comment Share on other sites More sharing options...
