can someone answer this suspension question?
desai18
  • 4 weeks later...
Suspension have any fluids???? Never knew and never heard of one. Good find for me.
If its very very mild noise then i suggest please forget it, as more cautious ear you give to your ride, you will assume and hear 100 things.
If ever something will go wrong, then you will hear it loud and audible decibel level then you can think or know yes this is wrong. These minor things eventually get you spend too much on guesswork, where you might know in end it is normal and every car and every LX have that small noise here and there.
Where is the squeaking sound coming from? .
Is it from the front or rear end of the car?
Have you lubed the bushings?
I agree with this line of reasoning. You should definitely find out where the sound is coming from EXACTLY to know what the problem is.
