Engine oil looks creamy whats wrong?
  • 10 months later...
Definitely its 100 percent correct either there is a leak or someone must have added coolant to engine oil
If even wanted for a day to act on this kind of situation this may damage the engine in a bad way.
if you mechanic is suggesting to change the engine then before buying have a look in the scrap yard market in sharjah
